degmwilliams
| posted on 22/7/12 at 08:25 PM |
I just wanted to let you know that after complaining about the chassis I have now swapped it for another which is a lot better. Thanks
Building a tiger Avon st170 (slowly)
snakebelly
| posted on 22/7/12 at 09:06 PM |
how far off was it? did they put up a fight?
dinosaurjuice
| posted on 22/7/12 at 09:16 PM |
so long as the individual suspension angles are set right i cant see any major issues, dont forget the bit touching the road is a piece of rubber
filled with air...!
degmwilliams
| posted on 22/7/12 at 09:27 PM |
One bit was 9mm out. There were quite good about it really. There were a few bits wrong, if they designed the chassis and did the drawings then the
chassis they make should match. It all depends on what person you are, if your happy to settle for something that's not quite right then your
finished car will be not quite right , my way of thinking is that if you start wrong it will end wrong.
phelpsa
| posted on 22/7/12 at 09:30 PM |
Where was the 9mm measured?
