<<  1    2  >>
New Topic New Reply
Author: Subject: Disaster recovery
The Black Flash
posted on 24/10/12 at 02:46 PM Reply With Quote
OK, so I'm basically back to the bushing then, which is fine. I can easily chamfer the edges so that's no problem.
The reason I'd like to use a turned bush rather than a simple crush tube + washer is so that I can tap a thread on the inside of the bush. Then I'll bolt straight into that (with locktight) and not have to have nut + bolt sticking into my footwell.
T66
posted on 24/10/12 at 05:20 PM Reply With Quote
Your second idea works better for me.
Personally I would plate all four faces of the chassis, well beyond the hole, however my fabrication is always belt & braces.
Reflecting on it, if you want belt & braces without removing the body, slip over a 3 sided box over the lower of the chassis, get the side plates as high up the hole as you dare, and weld everything.
4x2 box with the top cut off might slip over, and would be simple.
[Edited on 24/10/12 by T66]
coyoteboy
posted on 24/10/12 at 06:37 PM Reply With Quote
Personally I'd replace the member and find a better solution rather than supporting something requiring a chuffing great bush mid-span if at all possible.
T66
posted on 24/10/12 at 07:06 PM Reply With Quote
The whole member doesnt need replacing, that is a large clean hole in a otherwise clean chassis, if the access for welding is workable, theres no reason why a nice tight fitting U section couldnt be welded ontop. Bear in mind you could have it 30cm either side of the hole if space/shape permits.
coyoteboy
posted on 24/10/12 at 07:25 PM Reply With Quote
Doesn't NEED to be, no, but it's a bit of a botch to plug it. I just like a neat clean solution rather than a patch that'll probably take more work to do than doing a direct swap.
[Edited on 24/10/12 by coyoteboy]
T66
posted on 24/10/12 at 07:56 PM Reply With Quote
I dont think my suggestion is a botch, its a solution. By the time its painted most wont notice it. ....
The classic car guys repair far worse than that
coyoteboy
posted on 24/10/12 at 08:25 PM Reply With Quote
I do. We disagree. Not the end of the world though, I don't disagree it would work but it introduces lots of issues (vastly different wall thicknesses being different stiffnesses, harder to weld together properly (getting enough heat into the larger part to get good penetration) etc. Plated it'll stand proud so the bodywork around it won't fit as well. Just loads of little reasons I'd replace it fully rather than fix, but I'm a bit perfectionist.
The Black Flash
posted on 24/10/12 at 08:35 PM Reply With Quote
Well, the guy who designed the chassis said that a welded bushing would be "quite a nice solution" and that replacing the whole member was really not required.
If it were, I'd do it. But at this point, to do that I'd have to remove the floor, scuttle, and arches, which would all probably come off ok. But then also probably the inside rear panels, which would also mean the rear bulkhead panel, and the inner & outer side body panels. Removing these would be destructive or damaging and I'd probably have to replace some or all of them. I could really do without that scale of setback if possible.
Having trouble to muster the enthusiasm to do any work on it at all at the moment, it's gutting to be chopping bits out
T66
posted on 24/10/12 at 08:40 PM Reply With Quote
Boring world if we all agreed
but in respect of you being a perfectionist, I am most definitely the opposite
mcerd1
posted on 25/10/12 at 08:50 AM Reply With Quote
can't argue with that, he's a first class old school engineer
The Black Flash
posted on 25/10/12 at 11:22 AM Reply With Quote
Made some test pieces last night from smaller tube, and tested them against normal tube and tube with big holes drilled in it via the extremely unscientific method of a large hammer. I was pleased to confirm that a welded bush doesn't seem to noticably weaken the tube, (unless the weld is crap of course.)
daviep
posted on 25/10/12 at 11:31 AM Reply With Quote
Good stuff, looks like you are making are nice job of the build.
Davie
p.s. I'm sure some of our more theoretical builders will be along to tell you that your test results are not valid as the problem will be "cyclic stresses" or something else with bigger words.
Minicooper
posted on 25/10/12 at 11:37 AM Reply With Quote
Just weld it up, easy, 10 minutes and your done.
mcerd1
posted on 25/10/12 at 12:03 PM Reply With Quote
translation: hit it lots of times with a smaller hammer and see what happens
sebastiaan
posted on 25/10/12 at 06:54 PM Reply With Quote
No, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no, no!
You NEVER use the smaller hammer
On a more serious note; if you are comfortable with the welded in bush solution AND you did a succesful test then go for it. Our contraptions are actually quite crude in design, lots and lots of stress raisers and "incorrect" spaceframe constructions everywhere (well, on a locost at least; I'd assume a DAX is not THAT much better) yet we see very few chassis failures. Just keep an eye on the repair at regular intervals and it'll be fine.
The Black Flash
posted on 25/10/12 at 09:36 PM Reply With Quote
Davie
Oh, I'm under no illusions that it's a valid reflection of the real stresses in a frame. But it made me feel better because it seems as resistant to bashing as an undamaged tube, which I can assume will translate to reasonable strength elsewhere. Plus I got to bash something
Off for the weekend, but one side now stripped, so I'll get to welding it next week. Thanks all for the help, if nothing else it's been good to talk about it.
<<  1    2  >>
New Topic New Reply
