DREWB
| posted on 5/12/04 at 05:42 PM |
Cymtriks, you must be mighty proud of that work!! In fact its been checked out by me a number of times in the past, I'll ensure that we put the
new chassis on the forum then sit in a dark corner
Drew
Northy
| posted on 5/12/04 at 05:59 PM |
DREWB,
Where's W-ton Cumbria?
Graham
Cita
| posted on 5/12/04 at 06:37 PM |
Rough sketch GT 40 over locost frame
DREWB
| posted on 5/12/04 at 08:35 PM |
You can't call yourself NORTHY ,yer from down south mate! Workington is on the west coast between Whitehaven and Maryport 32 miles south of
Carlisle. Hope that helps.
CITA looking forward to checking file problem with software at the moment!!
Drew
Northy
| posted on 5/12/04 at 09:22 PM |
Ah, yes.
Not too far away then, if I can help let me know!
Graham
DREWB
| posted on 5/12/04 at 09:51 PM |
Thanks Cita OK Northy
To assist in engine bay design dimensions for the 302 sbf- Audi trans 5/6 speed(radio's would be a bonus) as anyone made an adaptor plate for
the above?
Which type of pedal box floor or hang, and from where? Drew
racer56
| posted on 5/12/04 at 10:36 PM |
Mr B., try here for some basic package info on the engines.
I'm guessing, but the weight seems to be for the bare engine (ie. no accessories) so allow a bit more for the weight of those, and also the
length they will add.
Some broad detail on the vehicle dimensions are:
Wheelbase 95in. 2413mm
Track Front 55in. 1397mm
Rear 55in. 1397mm
Overall Dimensions
Length 168in. 4265mm
Width 70in 1778mm
Height 40.5in 1028.7mm
Miscellaneous Heights
Base of Windscreen 28.25in 717mm
Top of Windscreen 39.2in 970.3mm
Top of Steering Wheel 31.35in 796.3mm
Minimum Ground Clearance 4in 101.6mm
Weight (Oil and water, no fuel)
Front 920 lbs 414kg.
Rear 1080 lbs 486kg.
Total 2000 lbs 900kg.
The Ford GT40 employs a semi-monocoque construction of 0.024 in. (0.61 mm) steel. Hinged front and rear panel sections and doors are of reinforced
fibre glass.
Allow space on the arches for wheels this size:
Front 6.5 x 15in.
Rear 8.00 x 15in.
I assume you have checked out these pics already?
http://www.gt40club.clara.net/kvaphotos.htm
List of parts used in kits (good for getting some other dimensions from) here:
http://www.gt40club.clara.net/technics.htm
theotherpartofVASPracing!
Cita
| posted on 6/12/04 at 08:05 PM |
It's surprising but a lookalike of the Ford GT can be build around a basic locost frame,given some modifications ofcourse.
rossco
| posted on 7/12/04 at 07:33 AM |
locost GT40
I may be able to help. I've built a replica and I race it.
Ross
ps how do you post pics on this forum?
DREWB
| posted on 7/12/04 at 10:04 AM |
Welcome Rossco, not sure about the pic's I'am sure someone will help, do you still have the GT40, as some additional measurements would be
helpful at this stage, which motor/tbox did you run. Welcome again Drew
rossco
| posted on 7/12/04 at 12:39 PM |
locost GT40
Check my website www.abbeysound.com.au/ross' cars
Ross
| posted on 7/12/04 at 12:43 PM |
correct link!
http://www.abbeysound.com.au/ross'scars.htm
DREWB
| posted on 7/12/04 at 06:45 PM |
Hi Rossco, top job did you buy in your chassis? Like the rear up-rights are they from the land down under, do you have any pic's of bare
chassis? Now starting to clear work space in shop and awaiting chassis plans, great site, Cheers Drew
krlthms
| posted on 7/12/04 at 07:15 PM |
Wow,
Those big V8's and ZF boxes look so muscular and kinetic.
The crossing over headers look pretty intimidating.
KT
| posted on 7/12/04 at 07:49 PM |
his link, not mine...
i particularly liked the pics of the rear suspension. nice
krlthms
| posted on 7/12/04 at 09:09 PM |
GT 40.5?
Rorty
| posted on 8/12/04 at 02:03 AM |
Ross
What are "dove" joints?
Cheers, Rorty.
rossco
| posted on 8/12/04 at 09:07 AM |
Dove Joints
Rorty have you never heard of dove joints? Well I haven't either so I'd better explain. I had an employee set up my website and not being
a petrol head like me, there is the inevitable typo here and there. Please replace Dove with Rose.
Drew I bought a rolling chassis and sep body From Roaring Forties and completed the build from there. The rear uprights were supplied as part of the
deal. I'll see if I can find some good shots of the bare chassis. The good news is the front uprights and rack are cortina. The chassis is
almost exclusively RHS so nothing tricky in that dept. Motor is 302 Ford with alloy heads and motec injection. I won't frighten you with how
much money has gone into it because I'm too scared to count it.
However constructing a chassis may not cost much more than the locost.
Glad you guys like the website, must update it.
Ross
kb58
| posted on 8/12/04 at 03:29 PM |
Yeah if you don't stay with stock parts it can cost a fortune... and who's going to stick with a stock engine, wheels, and tires? On a
car like a GT-40, you just *have* to do some engine work and give it nice wheels and tires, and big brakes. Just those parts alone can cost $10K-25K.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
krlthms
| posted on 8/12/04 at 06:03 PM |
Ross
Hello Ross,
C'mon, scare me!
How much for the headers? Do the right and left one come apart when you unbolt them, or are they intertwined when made? Why?
Very beautiful GT40 by the way, enjoy
KT
kb58
| posted on 8/12/04 at 08:43 PM |
I was meaning to ask that too, just how the headers are mounted to the engine. The pictures appear to show one huge header assembly. How do you get
the flanges into position. Is it really two parts?
And its book -
rossco
| posted on 9/12/04 at 06:50 AM |
The headers cost me approx A$2500 and were made by a very talented fabricator.He wanted to sand his tig welds down and I wouldn't let him, cause
they look so good.Oh yes I had them coated inside and out too and that cost another$500. I hope I'm not boring you, or explaining things you
already know but the headers are known as a crossover or 180 degree type. What this means on the v8 cylinder 2&3 and 6&7 crossover to the
opposite collector and this is what gives the GT40 it's wonderful exhaust note. The collectors are removeable from the primary pipes and then
the primary pipes can be removed one by one but only in the appropriate order. By the way I'm building a Locost because I wanted to build a car
from scratch and I'm in the Lotus club.
Ross
DREWB
| posted on 9/12/04 at 10:02 AM |
Rossco are you getting your u2u's Drew
Rorty
| posted on 10/12/04 at 04:47 AM |
quote: Originally posted by Glan Noye
I came across this today it might provide a starting point. http://www.rorty-design.com/content/beetle...ensive%20manual and
(IMG:http://www.rorty-design.com/images/Beetle_chassis02.jpg)
Food for thought,Glan.If link doesnt work try this one http://volksrods.com/forums/index.php?showtopic=7719
I was just informed of this site which is run by a bloke who bought one of my old mid-engine chassis for his GT40.
LINK.
Cheers, Rorty.
DREWB
| posted on 11/12/04 at 07:28 PM |
Hey Rorty, great links & photo's that mid engine chassis looked real strong, why not do a updated version solelly for the GT40? The adapter
plate looked very tidy too, what thickness plate was used & any top tip on how to do? thanks Drew
