<<  1    2  >>
New Topic New Reply
Author: Subject: Chasing an Ariel Atom, again.
beaver34
posted on 22/4/15 at 11:21 AM Reply With Quote
Originally posted by daveb666
The microphone is inside my cone filter, it is loud anyway but without the external mic you just get wind noise.
Daniel - I'm now on "sticky rubber", not 888s but semi slicks none the less. I haven't got the funds for protec or similar dampers so the Gaz will have to stay - brakes are a good possibility though so will be changed asap.
Vtecmike - its an ally one from eBay, I also suffer from heat. 6 laps at Blyton and I need to come in to let it cool. I'm adding flared panels next month to try and let the heat out faster. Blyton problem is there are no long straights so you never really get proper airflow.
enjoyed the id dave, is it water temps that are your issues?
Slimy38
posted on 22/4/15 at 12:15 PM Reply With Quote
Coozer - not more power needed, better brakes! The atoms pull so well out of the corners as they're both supercharged, I'm sat waiting for the boost :-(
[Edited on 21/4/15 by daveb666]
Dave, someone recently mentioned their turbo setup stalls when off throttle, was that your car? If so, is it worth coming up with a solution for that? It would certainly help with the boost delay, and it might give the turbo itself a few more years service.
coyoteboy
posted on 22/4/15 at 05:30 PM Reply With Quote
Errr most turbos stall off-throttle if there's no bypass/BOV, don't they?
Mog72
posted on 22/4/15 at 06:53 PM Reply With Quote
Really enjoyed that video, usually get bored of track day vids within a minute or so in !
Car sounds great too !! My Westy is just over 200bhp... Vids like this make me want more power !! Can't push my silver top anymore though without spending big bucks!!
theduck
Slightly off topic but which external mic do you use? Putting it in the airfilter is genius!
daniel mason
posted on 22/4/15 at 08:06 PM Reply With Quote
We have similar line through bunga bunga. Others use it differently! But yours is much better through the final turn! Lol
[Edited on 22/4/15 by daniel mason]
daniel mason
posted on 22/4/15 at 08:16 PM Reply With Quote
https://m.youtube.com/watch?v=v-GUBcMLDGg
daveb666
posted on 23/4/15 at 07:43 AM Reply With Quote
That is an epic finish
I had the same problem, with a 170bhp zetec. Just couldn't warrant throwing money into an engine that's 'meant' to be N/A when I could buy a turbo one already done.
I think so - don't have an oil temperature gauge so not exactly sure :p Water temp rises up to around 98-100 after 6 or 7 laps. If you do have a lap off boost it quickly cools down; the T28 is water cooled so I'm guessing that my rad simply can't keep things cool enough.
I've not noticed a lag, I was contemplating getting a recirc but the CA18 doesn't have one anyway so I'd be altering how the engine is usually plumbed together, plus I like the noise
ebay special - http://www.ebay.co.uk/itm/3-5mm-Flexible-Mic-Audio-External-Microphone-Adapter-for-Gopro-Hero-2-3-HD-/380997225744?pt=LH_DefaultDomain_3&hash=item 58b5344d10
You'll also need an extension lead for it.
jeffw
posted on 23/4/15 at 08:28 AM Reply With Quote
daveb666
posted on 23/4/15 at 11:13 AM Reply With Quote
Originally posted by jeffw
You think you have a fast car, then jeffw comes along
jeffw
posted on 23/4/15 at 03:16 PM Reply With Quote
That was running about 300BHP....since gone from 0.7Bar boost to 1.3Bar and 397BHP so it is a little more adaquate now.
This was the WSCC sprint last year....extra power but I'd ruined my soft tyres so I was running cold mediums which made it errr....interesting.
coyoteboy
posted on 23/4/15 at 04:28 PM Reply With Quote
That inlet temp is pretty high!
jeffw
posted on 23/4/15 at 05:23 PM Reply With Quote
I think that is because you don't normally see inlet temps during these types of events. You will find that is pretty typically on boost....
daniel mason
posted on 23/4/15 at 07:38 PM Reply With Quote
A new set of boots would Definately have seen you in the sub 70s laps jeff.
Makes me wonder how much under 65 I could have gone with some decent tyres and a helmet I could see out of
beaver34
posted on 24/4/15 at 08:36 AM Reply With Quote
does it keep rising? 98-100 isnt really high i dont think my elise gets up to that on track after 6 laps
mine is water cooled also and ive fitted a coolers external to the car on both sides, oil on one side water on the other that has helped massively with temps on both water and oil
jeffw
posted on 24/4/15 at 11:13 AM Reply With Quote
110 or higher would be an issue, 100 is fine.
<<  1    2  >>
New Topic New Reply
