<<  1    2  >>
New Topic New Reply
Author: Subject: Chassis construction: Alu vs steel skin?
lexi
posted on 11/1/06 at 12:10 AM Reply With Quote
My floor is 16g steel as is trans tunnel and bulkhead. Won`t make no difference to my car as I hope to lose three stone before it`s SVAd. My wife will be riding shotgun and if she happens to drop that purse of hers on an ally floor..
Alex
C10CoryM
posted on 11/1/06 at 12:34 AM Reply With Quote
Pretty well all cars here are just spot welded together. Stronger/lighter than rivets but weaker than bonding.
Ive never seen a spot welded car come apart at the seam and I have twisted the hell out of a few of them .
Had a camaro that tore the quarter panel, tore out the door striker, and twisted the car enough the dome light stayed on but there was no damage to the spot welds. Little too much power/traction for the stock body.
Spot welded steel will be just fine. having said that, I intend to use SS structural rivets and also bond the aluminum to the chassis. I want to leave the sides bare aluminum. Havent decided what to do on the tunnel though. The thought of using aluminum there and having a u-joint fail scares me. Not a V8 car though so less likely than I am used to I guess.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
locost_bryan
posted on 11/1/06 at 01:58 AM Reply With Quote
Cymtriks recommends welding a steel panel under the nose as part of the torsional rigidity improvements.
I've been considering using the roof off my donor Suzuki van for the floor (as suggested by Uncle Ron) - it has stamped ribs running down it's length, so would be nice and stiff.
The original 7 was a little on the flexible side - I'd like mine to be a little stronger around my vital bits (and don't mind a bit of extra weight closer to the ground)
... and I'll save some weight by going for an axle, gearbox and all-alloy engine that are heaps lighter than Ford's
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Philippe
posted on 11/1/06 at 10:03 AM Reply With Quote
Cheers.
R-Thanks for your reply.
Indeed spot welds need dynamite to be separated. I am currently rebuilding the body of my Suzuki Samurai and I could not separate the plates around spot welds. I had to plasma cut 1" holes around them. So I am confident that welding light gauge sheet steel on a Locost tube frame will be the strongest bond possible. Your idea of using SS rivets/aluminium plates is good too. I would still introduce a bonding agent (epoxy) though in order to provide the skin to chassis bond more integral strength and prevent water penetration in steel tubes.
I hope these thoughts are usefull.
Take care.
Ps. I like the photo of your sister on the left.
Philippe
[Edited on 11/1/06 by Philippe]
posted on 11/1/06 at 11:12 AM Reply With Quote
maybe nowadays but I recall a story about Marina or some other BL car from the 70s. The owner would go to the countryside and park the car. He would hear a strange pinging noise once in a while - turns out it was the spot welding coming apart!
posted on 11/1/06 at 11:19 AM Reply With Quote
Get one of these they're good for splitting panels. I've used them or just drilled through the welds and peeled them with grips or split them with a chisel but that tears the metal so you need to be careful if you are reusing it. You can reweld in a different place to recycle panels though.
NS Dev
posted on 11/1/06 at 11:56 AM Reply With Quote
Originally posted by britishtrident
Originally posted by NS Dev
The problem will be that using 0.5mm steel (as opposed to 1.2mm ally) will mean that the steel will wrinkle when welded, almost impossible to stop this happening with very thin section sheet steel.
R-I was refering to sequential spot welding. This is the way the industry stitches car bodied together. Punch holes all around the perimeter of your panels, turn the amp at the lowest on your mig welder, weld one second hole at the time, etc.... No distorsion, no buckling, perfect.
Philippe.
Yes ;-) it buckles or to put it anotherway because of the greater thickness an aluminium panel is stiffer in bending than a comparable steel panel -- which is why aluminium and magnesium alloys are such excellent materials for making road wheels.
You mean what I would call plug welding, i.e. puddle welding through punched holes with the MIG.
I use this technique a lot, but it still wrinkles 0.5mm steel sheet, in fact it still wrinkles 0.8mm sheet, even when pretensioned.
NS Dev
posted on 11/1/06 at 12:07 PM Reply With Quote
Originally posted by 02GF74
is it not possible to spot weld the thin sheet to the square tubes or the difference in thcknesses too great?
using steel has anther disadvantage - rust! so you need rust treatment and paint = more weight!
the question is how much rigidity you gain by a more solid join of sheet to the frame, if you knew that, then maybe you could use lighter tube so shed some weight there.
Lotus or at least Arch Motors used 1.2 mm round tube for the spaceframes. 1.6 RHS is easier work with.
Early Lotus space frames were a lot sparser than the Locost --- somewhere on the net is a picture of chunky Chapman holding up an Eleven chassis-- just try that with book chassis.
With the Seven Series 2 Chapman tried to take even more weight out cutting out nearly all of the diagonals -- the result was a lot of broken chassis (mainly fatigued brazed joints), with the late Series 2 and Series 3 the missing members were re-instated. Locost are about twice the weight of a Lotus Seven S2 chassis.
Chasing grams on the chassis isn't worth it, the chassis dosen't way a lot compared to the bits bolted on to it.
The last line of the above is one of the best observations made on here for a while!
Philippe
posted on 11/1/06 at 01:08 PM Reply With Quote
Philippe.
R- Thin steel in my experience will buckle if the welding sequence causes it. I believe that I can limit the buckling effect by welding away (in a sequential fashion) from the center of the work. But you are right there is always a bit of distorsion on thin steel no matter what you do. Nothing that could not be flatened out using a torch or in the worse case body filling.
Philippe.
Alan B
posted on 11/1/06 at 01:15 PM Reply With Quote
.......Chasing grams on the chassis isn't worth it, the chassis dosen't way a lot compared to the bits bolted on to it.
I'll add my 100% endorsement too....there are many, much better places to save a few pounds.
posted on 11/1/06 at 01:23 PM Reply With Quote
For me, I must lighten the nut holding the wheel (yes, I know I've said it before... quite recently in fact!)
NS Dev
posted on 11/1/06 at 01:27 PM Reply With Quote
Surely that one Nyloc doesn't weigh THAT much does it?????
kb58
posted on 11/1/06 at 03:39 PM Reply With Quote
"Chasing grams on the chassis isn't worth it, the chassis dosen't w[eigh] a lot compared to the bits bolted on to it."
But only if that is followed through - I find it's actually the opposite. I think instead the thought "it's just a few ounces, it won't hurt", happens to just about every part of the car.
It's just like dieting where people cheat, "it's just a little bit." That thinking, carried to its logical end, results in overweight people - and cars. I realize we don't have the buget for carbon this or titanium that, but it's still important to always be asking, can I make this (and every) part lighter.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
TheGecko
posted on 11/1/06 at 11:35 PM Reply With Quote
It's well worth reading "Driving Ambition" by Doug Nye (and Gordon Murray & Ron Dennis) about the design and manufacture of the McLaren F1. Murray set a 1000kg weight target and was fanatical about chasing every spare gram. In the end the road-ready car weighed (from memory) 1100kg, amazing for a 3-seat 5 litre V12 autobahn weapon! Murray said that only setting the (probably unachievable) 1000kg target had kept the design/development team focused enough to reach the (still impressive) 1100kg end result.
Now, none of us are building 300km/h+ supercars (well, I'm not - anyone else want to claim otherwise?) but, as Kurt points out, it's possible to let a "Near enough is good enough" attitude compromise the end result significantly. So, I say, think about those extra grams, even if you decide in the end that it's not worth saving them. At least then it's an informed decision rather than a "swept aside, too small to bother about" dismissal.
Will my car be heavier than it could be. Absolutely! Will I cry tears of blood over that? No because, wherever possible, I have considered the factors and made a decision. In a lot of cases, that decision was that I would accept a (probable) weight penalty in exchange for ease of construction or availability of materials or peace of mind about strength or any of a hundred other reasons.
To try and drag this polemic back on topic, my car will have bonded (sikaflex or equivalent) and riveted aluminium skins. I'm not too concerned about corrosion since I intend not to park the car underwater any more than neccesary. Living on the dryest continent on Earth helps but, that said, we've had 75mm/3" of rain this year and it's only the 12th of January.
Anyway, enough rambling from me. I'm back to the garage to make some more informed, considered decisions about engine bay tube sizes. I think I see a way to save about 4kg!
Dominic
posted on 12/1/06 at 12:36 AM Reply With Quote
That would be a button weld
NS Dev
posted on 12/1/06 at 12:41 AM Reply With Quote
I'm tired so a short reply!
Yep, in order to achieve the ultimate we need to do everything to the ultimate................................................................................................................................but then we must not over complicate things!
Keep It Simple Stupid, as they say!
Look at the Ultima GTR (to current demo car spec)......vastly quicker in a straight line than the McLaren, quicker around a track, less than 1/10 the cost, nearly 200kg lighter, 100 times simpler and uses an ancient engine design that still makes more power!!!! There is no stressed carbon fibre on the car, a steel spaceframe chassis, pop-rivetted alloy panels etc etc.................................................................... Simple is Quick, Colin Chapman taught all of us that but nearly all have forgotten it completely.
Simplicity is the reason that to save weight in my 7, I am simply not bothering with things that I don't need! Maybe I can save a few grammes on the chassis, but having no instruments saves a lot and why do I need them???? What does trim do exactly???? Don't need that. No windscreen, no heater, no wipers, no washers............nothing that I don't need in order to use the car for what it was meant for...FUN!!
posted on 12/1/06 at 08:39 AM Reply With Quote
My sentiments exactly!
Mark Allanson
posted on 12/1/06 at 02:27 PM Reply With Quote
Or even a plug weld!
NS Dev
posted on 12/1/06 at 03:41 PM Reply With Quote
I know, I'd call it a plug weld to anybody in the UK!
I used the "nondescript" terminology on seeing that the person I was answering was not from our shores and may not understand our terminology.
posted on 12/1/06 at 06:36 PM Reply With Quote
It had already been called a spot, plug and puddle weld, I just thought I'd throw another one in there
NS Dev
posted on 12/1/06 at 11:37 PM Reply With Quote
lol
locost_bryan
posted on 13/1/06 at 04:10 AM Reply With Quote
Wasn't that Mazda's approach with the new MX5 - shave a little bit of weight off every component (even the door handles!)
Bryan Miller
Auckland NZ
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 13/1/06 at 04:33 PM Reply With Quote
has anyone tried epoxying the floor on rather than using pu glue which isnt rigid so wont kelp with the stiffness of the chassis?
NS Dev
posted on 13/1/06 at 05:22 PM Reply With Quote
no but epoxying it on is a much better idea!
Would have done but for the expense of the epoxy!!
smart51
posted on 13/1/06 at 05:56 PM Reply With Quote
Epoxy can be a bit brittle and doesn't stick to its full potential unless the surfaces are impossibly clean.
PU is very sticky and is flexible. it is less likely to brake or come loose even though it is perhaps less strong.
<<  1    2  >>
New Topic New Reply
