<<  1    2  >>
New Topic New Reply
Author: Subject: Progress .... So alloy or steel floor ?
big_wasa
posted on 14/3/06 at 09:17 PM Reply With Quote
Wont be cf its a "locost"
907
posted on 14/3/06 at 09:31 PM Reply With Quote
I think I'll stick with my stainless floor.
If I run over a pheasant I don't want game pat'e in my lap.
Paul G
DIY Si
posted on 14/3/06 at 09:34 PM Reply With Quote
But then you're wasting a perfectly good pheasant. At least if it is in your lap you can take it home and get the missus to put it in a pie!
907
posted on 14/3/06 at 09:52 PM Reply With Quote
But if it bounces off a nice smooth stainless underside I can stop and pick it up, undamaged.
And sooooo hygienic too.
Paul G
DIY Si
posted on 14/3/06 at 09:57 PM Reply With Quote
Ahh, a very good point indeed sir. And, havin gjust knocked it over, it should be minus a few feathers, thus saving her indoors time and effort!
MikeR
posted on 15/3/06 at 12:16 AM Reply With Quote
plus there is no risk of breaking a tooth on lead pellets!
kb58
posted on 15/3/06 at 01:23 AM Reply With Quote
Originally posted by MikeRJ
I would go for a steel floor purely because it can be welded in place rather than pop riveted. Riveting the side panels is fine, but the floor has to support the weight of your legs and the rivets are in a bad location wrt corrosion, especialy if your 7 has to live outside.
In a 7-type car how much weight can you put on the floor panel? Isn't the floor such that you can't stand on it because of the dash?
About rivets, yes there is a issue with corrosion, but no more so than with welding. A welded panel will get moisture in from the sides and top, like when driving through a puddle. Worse, it's for certain rust will start since there is no paint coverage between the floor pan and the tubes. If silicon sealer is used along the edges to prevent moisture intrusion... that can be used on riveted panels too.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
NS Dev
posted on 15/3/06 at 08:49 AM Reply With Quote
Nearly every westfield built has a thin ally floor that is rivetted in.
I don't see many where it has fallen out?
stevebubs
posted on 15/3/06 at 09:59 AM Reply With Quote
11/12 years on and my fury floor is still there....
Dutchman
posted on 15/3/06 at 03:45 PM Reply With Quote
I was thinking on 2/2.5mm Aluminium Diamond Plate ... it is not slippery and a little Race look
but maybe 4x4 patern or eaven 1x1 I'll see what is bether looking
Tarzan English with foreign accent!
MikeR
posted on 15/3/06 at 06:08 PM Reply With Quote
i remember reading of a couple on the se7ens list that have had floor falling out problems ....... but a couple in how many?
cymtriks
posted on 21/3/06 at 10:36 PM Reply With Quote
There have been cases of rivets fretting out over time with ally floors. A stiffer chassis will generate less problems in this area but a normal book chassis is only just stiff enough.
I'd use a stitch welded steel floor in 18 gauge (1.2mm). Heavier, yes, but much more durable for road use.
procomp
posted on 22/3/06 at 09:02 AM Reply With Quote
Hi just my 2 pence worth but whilst repearing a number of the the racing locosts with steel floors that have been powder coated after the floor has been stitch welded . what you find is that the coating dose not stop rain or damp getting inbetweenthe floor and chassis and on one certain car after removing a section of floor to repair chasiss a large area of the lower flat section of the floor tubes where heavily corroded.
And just to stop confusion the only race series that requires a sleel floor is the locost race championship. Kitcars and rgb can both use ally floors.
Oh and the 750mc have recomended that steel floors on the locosts might be beter rivited on for the reason above as they have no way of controlling the weather so we might end up getting a wet race ocasionaly.
cheers matt
(edited)
ps in 20 years of working with westfields i have never seen an ally floor come detached or have somthing go though the floor to the cockpit area
cheer matt
[Edited on 22/3/06 by procomp]
Triton
posted on 22/3/06 at 09:06 AM Reply With Quote
Ali floor everytime...16swg with a bucket full of rivets and sikaflex for good measure.
www.tritonraceseats.com
www.hairyhedgehog.com
NS Dev
posted on 22/3/06 at 10:14 AM Reply With Quote
yep that's what I have done. Floor is quite flexible but I can't see it coming off!!!
<<  1    2  >>
New Topic New Reply
