zetec7
| posted on 2/5/06 at 07:51 PM |
Agreed - what I did was to get in from either side as best I could, but don't go much further than that. The first time, I turned up the
arc/gas/wire speed, and burned a hole through the tubing in about the most inaccessible place on the frame, inside the vee. THAT, I had to fix.
I've looked at several other frames, some didn't even bother with the inside angles, others just got in from either side as best they
could.
NS Dev
| posted on 4/5/06 at 09:41 AM |
You'll find with a slightly squashed shroud, a few more amps, touch more gas and a practice run on some scrap set to the same angle so you can
predict where the wire will go (as it never goes in a straight line on hobby welders! ) you'll weld it as-is with no problems.
There's no right or wrong solution, but that one will work and I'd rather weld all round, and would never go near a weld with sealant.
