RK
| posted on 23/5/07 at 08:24 PM |
I had thought of that. I had a bad accident a couple of years ago actually, where I was hit in the rear quarter panel, and the hit my head took onto
the Headrest, gave me a concussion, post-concussion syndrome etc. Not fun and the pills cost a fortune.
| posted on 23/5/07 at 08:31 PM |
what you need is a free national health service!
Alan B
| posted on 23/5/07 at 08:40 PM |
I thought Canada did?
Or freeish at least...
RK
| posted on 23/5/07 at 09:12 PM |
Not for drugs. Anything else, yes. For example, when my hand was broken in two from a mountain biking accident, it was repaired the next day!
Some oldsters can be covered for drugs by their provincial plans (Quebec does it for example), but not for tax paying people of a certain age.
| posted on 23/5/07 at 09:24 PM |
ah well, you still have to pay for drugs round here too...
(poor joke, i mean 'recreational' ones...)
C10CoryM
| posted on 24/5/07 at 04:01 AM |
Have a look at the SCCA or FIA rulebooks.
SCCA is online and has a good write up on rollbars/cages.
I know a rollbar has to be 2" above the helmeted head for SCCA. It works for me because that gives me the minimun required angle between the
main hoop, and the down tubes (30 or 35degrees, I forget).
Im of the mind that rollbars and knee bars are best for the street. And full halo/cage is best for track where you have a helmet, GOOD padding, and a
neck protector of some sort. No point caving your head in on your "safe" roll cage on the street.
"Our watchword evermore shall be: The Maple Leaf Forever!"
worX
| posted on 24/5/07 at 11:11 AM |
dimensions...
Hi again Adrian,
I have estimated where I think the front diagonal should start.
The one I have is nearly in the middle, and I think that to get the diagonal to be Centralised at head height it would need to be moved over around
90mm, but to err on the side of caution (to give the driver a touch more room than the passenger) I would suggest around 65mm toward the Driver
side!
All this can be checked however just to ensure it is still correct for you, by just doing a mock up. You could use welding/brazing rod/wire etc for
this?
With regard to Cory's post, if you want to make it comply with that SCCA Reg. My NON helmeted head is about 65mm below the Bottom of the roll
bar (50mm tube as above) and therefore helmeted head is probably 25-30mm below the bottom of the tube.
I don't know any of the rules and regs of the SCCA or FIA, but at least you have a (sort of) datum point if you want to find out yourself!
cheers,
Steve.
edited to add: PS - Spiderman 3 was a big pile of poo (of the poo-est kind too!) and thats coming from a pretty avid Spidey fan!
[Edited on 24/5/07 by worX]
bpgoa
| posted on 26/5/07 at 09:05 PM |
ordered
as per spec, but changed to 50mm cds..
will let everyone know the cost ... later
On and On the River flows... We the Undertow
t.j.
| posted on 27/5/07 at 10:09 AM |
Drugs are freely excessable around here if that's the problem. But i'm sure it won't make you happy on the long run.
[Edited on 27/5/07 by t.j.]
