<<  1    2  >>
New Topic New Reply
Author: Subject: suspension bolts
DarrenW
posted on 28/9/07 at 10:18 PM Reply With Quote
Did Mk not supply you with suitable bolts? Why not use the apprpriate grade steel bolts?
As syd says, you can use whatever bolts you want as long as the correct specs and applications are observed. But i dont see why exotic bolts are needed in these areas. Plated steel should work just fine. A bit of copper slip inside the crush tubes will halt unwanted corrosion.
<<  1    2  >>
New Topic New Reply
