<<  1    2  >>
New Topic New Reply
Author: Subject: Making it by a noobie
Ninehigh
posted on 4/10/08 at 08:25 PM Reply With Quote
I heard the best way to keep the seat next to you free is not to pile your stuff on it, but when someone approaches pat the seat and smile :-D
MakeEverything
posted on 4/10/08 at 08:29 PM Reply With Quote
Thats good fun on a late night home on the tube!
Kindest Regards,
Richard.
mark chandler
posted on 6/10/08 at 10:00 PM Reply With Quote
Just to add, mine is TIG welded, square lower frame, round tube upper and diagonals, makes it much easier to rivit and glue the floor.
hughpinder
posted on 9/10/08 at 08:31 AM Reply With Quote
I'd go for square tube - easier to cut, and for a given diameter of tube more weld length to hold it together!
I thought the main reason 'proper' track cars use round tubes is the much better availability of high tensile grades of steel seamless tube in round compared to square. (Seamless tube is supposed to be better as welded tube can allegedly split along the weld line - also heat effect of welding process can weaken tube - but for your first chassis I wouldnt worry about any of that!)
Regards
Hugh
MakeEverything
posted on 9/10/08 at 01:54 PM Reply With Quote
Just keep it simple. Use square. For the size and weight of the car, it wont make any difference for 'normal' use.
As hugh says, its easier to weld too!!
Kindest Regards,
Richard.
<<  1    2  >>
New Topic New Reply
