Kelvin
posted on 11/1/07 at 02:17 PM |
Ta muchly ![](/images//smilies/bigsmile.gif)
mark_mcd
posted on 11/1/07 at 06:11 PM |
so what are the changes over the old setup? is this talk of the camber etc all sorted out?
dilley
posted on 28/3/07 at 05:43 PM |
Is ther much room lost under the bonnet /nosecone compared to the old indy?? can anyone post a pic of each to compare???
martyn_16v
posted on 28/3/07 at 08:14 PM |
This has had the bulkheads moved back about 3 inches. The tunnel area is still a pretty tight fit but there's a bit of space in front of the
engine, dont know how useable the space will turn out to be though. I haven't offered up any of the bodywork yet to see how much room there is,
but obviously you'll lose a bit of space in the nosecone where the shocks are now.
![](http://i98.photobucket.com/albums/l276/martyn_16v/Indy/040307-007.jpg)
matt.c
posted on 28/3/07 at 09:44 PM |
martyn_16v
Which master cylinder are you using on the new spec-r?
Have you had any fouling problems with it?
matt
martyn_16v
posted on 29/3/07 at 07:44 PM |
I did have a problem with the one off my sierra donor, it has a mounting lug coming off the underside which fouls on the lower chassis rail. I had a
look at a couple being built up at MK a couple of weeks ago, they had a different sierra m/c to the one I had that fits OK, although there is a fairly
tight bend on the front brake line as soon as it leaves the union to clear the chassis rail. I'm using a mk2 golf master cylinder now, I had one
kicking about in the garage so I offered it up and it fits much better, the outlets are all pointing upwards and there's 4 of them if you buy a
new one. The only thing I do need to do to it is chop down the nose the pedal pushrod fits into, it's a bit on the long side.
matt.c
posted on 29/3/07 at 08:01 PM |
Do you know which one MK are using? Is it a willwood or something else?
Also have you got anymore build pics?
[Edited on 29/3/07 by matt.c]
martyn_16v
posted on 29/3/07 at 10:27 PM |
It was a sierra one they use, just not the same one as mine came with. I think i've seen three different master cylinders on sierras so far, two
of them look like they'll go on fine, just not mine Never mind, got a shiny new one now and it was cheaper than a recon sierra job.
Build pics here, I think i've got some more recent ones to get around to
uploading. Despite working with cameras for a living my pictures are pap though ![](/images//smilies/smile.gif)
