thekafer
| posted on 21/9/03 at 08:36 PM |
18g steel,and I plan on using a bead roller
inbetween frame members w/the beads running laterally,for added rigitity.
No, I dont own a bead roller but I did talk my employer into buying one for a job we did...and plan on bead rolling my floors after hours under cover
of darkness..
Oh, single piece.
Fletch
I'd rather have a bottle in front of me than a frontal labotomy...
Browser
| posted on 22/9/03 at 03:19 PM |
of darkness..
Did he veto the English Wheel, guillotine and sheet metal brake, or have you not asked him yet?
Dunc
| posted on 22/9/03 at 04:29 PM |
20swg aluminium sheet,1 on bottom of chassis rails 1 on top of chassis rails, VHB taped onto chassis, then injected with polyurethane foam to add
rigidity and turn floor into a stressed member. Would also help with noise reduction
Can also be used for side panels.
MustangSix
| posted on 22/9/03 at 11:36 PM |
I used a one piece section of 18ga galvanized steel, glued with urethane adhesive and riveted every 3" or so along every lower tube.
In a test with glue alone, I had to nearly bend the steel sheet to destruction to remove it from the tubing. With the addition of a few rivets, its
going nowhere and has the advantage of being sealed at the same time.
jcduroc
| posted on 23/9/03 at 04:47 PM |
Very interesting Duncan
Please (excuse my ignorance) what does VHB mean?
To inject the PU foam , admitting that both alu sheets extremeties are "closed" by the tubes to which they attach do you make a hole to be
covered with a screwed cover afterwards? (Sort of those cover for the fuel bags in '70ies sports cars in the side ponds?)
JCM
thekafer
| posted on 24/9/03 at 01:00 AM |
Since we are an aircraft completion center,
we already had the shear,brake ect..
However,he did say he'd like for us to build a small e-wheel.
Everybody at work are car nuts.We all have projects squirled away within the hangers. In fact they let (even encouraged)me build a frame jig and my
frame there!
We're very fortunate to have a job situation like this, so we all chip in with things that need attention around the hanger on choosen
weekends....Makes for a great moral booster!
Fletch.
[Edited on 24/9/03 by thekafer]
