Matthew_1
posted on 20/1/04 at 10:25 PM |
Chassis for short arses!
I've just finished a chassis built to my own custom suspension design and width, but to book lengths - because I assumed it would be long
enough. Wrong. I'm 6'1 and with Cobra Roadster seats I haven't got a chance!
Chassis rear section (the biq square) needs to be at least 100mm longer! Time to reach for the grinder.
****ed off dosn't even begin to describe it !
Anyone else of a reasonable size find they fit in ok ?
200mph
posted on 20/1/04 at 10:29 PM |
I am 5'8 ( well maybe), and the book chassis is tight, very tight, compared with a normal car of course
Us small folk are here for a reason
Mark
stephen_gusterson
posted on 20/1/04 at 11:30 PM |
'the book' doesnt really use seats......it upholsters the rear panel - that saves room.
I think there is 4 or so inches behind my seats....but then my car is longer anyway - but I can see how the angle of the seats to angle of rear panel,
and seat tickness, steals space.
im 5ft 9
atb
steve
posted on 21/1/04 at 08:38 AM |
I'm 6ft, my chassis is 'book', and I'm wondering if I've mounted my seat a bit too far back! I have to stretch a bit to
depress the pedals fully.
Before you carve up your chassis you might like to try thinner seats...
rgds,
Mix
posted on 21/1/04 at 08:57 AM |
6', book length chassis and roadster seven seats work for me.
(But the first thing I'll do when I'm next in the garage is to check again)
Are you using runners and if so do they allow the seat to touch the rear panel?
Mick
[Edited on 21/1/04 by Mix]
Matthew_1
posted on 21/1/04 at 09:19 AM |
The problem seems to be the angle of the seat and/or the angle of the seat-back part of the chassis. The seat bases themselves will go back about
100mm, but then the seat backs will go through the chassis back. Think I'll have to redesign the chassis seat backs to be slightly less vertical
stephen_gusterson
posted on 21/1/04 at 10:35 AM |
think thats the situation I described....
david - have you just got tiny legs
atb
steve
posted on 21/1/04 at 11:50 AM |
I think I've got 'duck's disease'
(my @rse is too close to the ground)
No - I'm normally proportioned - if you ignore the spare tyre...
DJ
posted on 21/1/04 at 12:47 PM |
David,
I think carrying the spare tyre about your person is a good use of space myself!
It also saves the effort of making an additional bracket to fit to the rear of the car for spare tyre storage
Nick
Alan_Thomas
posted on 23/1/04 at 03:24 PM |
Height is not everything to consider my 6' 2" is because of grossly long legs and I luckily found out before building that std was no good
for me I added 6" to the overall wheelbase adding 3" to the main cockpit section and 3" to the scuttle area. I did this because I
thought it would still keep its proportions. It does, but it causes huge headaches in non std Bonnet, side panels, steering and scuttle. no chance of
using f'glass bits.
If I did it again I would leave everything forward of dash the same dimensions as book - Alan
James
posted on 23/1/04 at 05:16 PM |
using f'glass bits.
I basically did the same- and regret doing so for the same reasons!
James
Kitlooney1000
posted on 23/1/04 at 09:10 PM |
I'm 6'2"
with a standard size chassis and westfield seat pads, an 11" steering wheel, pedals are floor mounted, and the chassis is fine. just need to
loose some weight of my arse..
"I think I've got 'duck's disease'
"all locosters have this disease!
[Edited on 23/1/04 by Kitlooney1000]
TPG
posted on 24/1/04 at 05:23 PM |
Length wise my car is as book.I put 4" extra on the copit width.I've used seats from a suzuki carry/bedford rascal van,recovered.These are
very comfortable and recline and slide.I've a standard Sierra pedal box in and at 6' & wearing rigger boots have no trouble in fitting
in and driving.
posted on 24/1/04 at 08:37 PM |
I've been thinking about this, and came up with a suggestion - sit in the car with no seats whatsoever. If you're stretching for the
pedals a lot then an ordinary seat will probably be OK. If you're only stretching a little bit then you may want a thin seat (drop-in seat
pads), but if you're still feeling cramped then you want a bigger car!
rgds,
stephen_gusterson
posted on 25/1/04 at 12:44 AM |
my suggestion is make getting seats one of the first things you do. dont even think of making pedals and stuff until you chan check space in the car
is right.
if you srew up before the chassis is panelled and floored you can correct it with a grinder/cutter and welder fairly easily.
atb
steve
