New Topic New Reply
Author: Subject: McSorley +442 driver's height
l0rd
posted on 20/11/08 at 10:05 PM Reply With Quote
I have been trying to design my own chassis because i believe i am too tall to fit in a normal locost. Can all the McSorley +442 builders post their height, shoe size, weight and personal opinion about how comfortable you are so i can check if i can go down this road as well.
I am 6Ft 6" wear size 12 shoes and I'm about 115Kg
Thank you in advance
L0rd
omega 24 v6
posted on 20/11/08 at 10:13 PM Reply With Quote
5ft 10
105kg ish
size 8 feet
son is 6ft 2 ish and size 12 feet and he fits in ok with the seat farther back than me. I need the seat almost at it closest point.
some of the ready made chassis would accomodate you though i'm sure
RichardK
posted on 20/11/08 at 10:22 PM Reply With Quote
6'5" size 12 shoes probably about 14 stone, seat nearly all the way back but it's comfortable.
Rich
Gallery updated 11/01/2011
JohnN
posted on 20/11/08 at 10:28 PM Reply With Quote
6' 3"
115Kg
size 12 shoes
Seat as far back as possible, in fact I bent the cobra drivers seat to be more upright as there was a lot of wasted space behind the seat at the base.
Removable (snap-off) steering wheel makes getting in & out easier
Pedals hung from the top so as to maximise space in the footwell, allows my left foot to be behind the clutch pedal when in top gear
All in all, it is comfortable and not cramped
l0rd
posted on 21/11/08 at 08:58 AM Reply With Quote
My main problem would be my quite tall legs. Has anyone tried increasing the chassis to a +642 ? What problems would i get if i try that just in case i go down this road?
JohnN
posted on 21/11/08 at 09:57 AM Reply With Quote
I doubt if you need to go to +6 (if you do you're in Viento territory)
In my experience, making sure that the seat can go as far back as the rear bulkhead allows and that the pedals are as far forward as the front bulkhead allows, should ghive enough leg room for you.
Have you tried sitting in a built 442?
mr henderson
posted on 21/11/08 at 10:16 AM Reply With Quote
I also am quite tall, with a lot of that height being in my legs, and I can well appreciate your concerns.
I would say that most chassis designs can be increased in the cockpit section without problems, and will also allow easier entry and exit, partly because that will put the steering wheel further away from the seat, (but presumably well within a tall person's reach)
It may be that you don't need more than a 442, though, so maybe there is someone near you who's car you could try, or maybe you could mock up the relevant parts of the cockpit with whatever comes to hand, before deciding
John
l0rd
posted on 21/11/08 at 11:23 AM Reply With Quote
Unfortunatelly as far as i know, there only one person that is building a +442 near where i work but he is in an early stage.
Is there anyone else near Gloucester or Trowbridge that has one who is willing to let me try fitting in it?
Daddylonglegs
posted on 21/11/08 at 06:44 PM Reply With Quote
At risk of hijacking your thread, I would be interested too. I am 6' 4" and 200lb, size 11 plates.
I am also building a +442, and am at the basic chassis stage (still to complete the rear end yet). I have taken the chassis out on to the drive for a 'test fit' and it seems that all should be fine. It will depend on my seat choice and pedal configuration though.
I will watch with interest.
JB
l0rd
posted on 22/11/08 at 10:24 PM Reply With Quote
I have been looking on both the McSorley and Haynes roadster to check on the differences. The ones that i found is the +4 inches on the footwell, and the + 4 on the engine bay. As i like the front end of the Haynes roadster, i might build a hybrid Haynes ones with the changes of the Mcsorley design. Although, the McSorley design on the fron is the same as the Haynes, i might go for a +4 as it would look more appropriate and in proportion to the rest of the car. I am trying to calculate how much steel i will need to order though as quite a few extra sections will need to be longer.
I will keep posting updates.
RichardK
posted on 29/11/08 at 05:49 PM Reply With Quote
Next time you're passing Knaresborough, pop in mate
Rich
l0rd
posted on 30/11/08 at 12:53 AM Reply With Quote
Knaresborough is far far away unfortunately. Although if i drive by, i will give you a shout.
New Topic New Reply
