<<  1    2  >>
New Topic New Reply
Author: Subject: Chassis paint
Miks15
posted on 22/12/08 at 09:22 PM Reply With Quote
Chassis paint
What sort of paint should i be looking for? Anyone recomend anything?
Also do i need to prime it first (red oxy primer etc?) or can you get self priming paint?
Mikkel
chris_smith
posted on 22/12/08 at 09:26 PM Reply With Quote
maybe try this
linky
maskell01
posted on 22/12/08 at 09:31 PM Reply With Quote
I Used Hammerite!
Thinned down with white spirit then sprayed through a gun!
skodaman
posted on 22/12/08 at 09:45 PM Reply With Quote
Using David's zinc based grey primer and satin black on mine (both cellulose).
Trying to buy locally proved impossible but it's available on ebay no problems.
Skodaman
skodaman
Skodaman
austin man
posted on 22/12/08 at 09:53 PM Reply With Quote
I would second that go for a zinc based primer (unless your looking at saving weight as it is a heavy paint, then hammerite/ smoothrite it for final protection. A lot of people have their's powcer coated this can blister if not done correctly
Miks15
posted on 22/12/08 at 09:56 PM Reply With Quote
The hammerite stuff seems to be direct to metal stuff, would this be ok? Dont to have to spend more money any time messing with primer
minitici
posted on 22/12/08 at 10:05 PM Reply With Quote
Hammerite / smoothrite does not stick well to nice new shiney steel - prefers rusty metal
big_wasa
posted on 22/12/08 at 10:06 PM Reply With Quote
I sprayed mine with synthetic paint. Its like cellulose. It took three weeks to go hard enough so it didnt chip by looking at it.
I wish I had tried epoxy mastic. Its on ebay and the seller is in Market Deeping. just dont brush it on. See Nitram's posts for details
Miks15
posted on 22/12/08 at 10:08 PM Reply With Quote
mightr just leave it out in the rain for a bit then
SO it wouldnt be suitable without some other primer then?
mistergrumpy
posted on 22/12/08 at 10:09 PM Reply With Quote
I used Hammerite direct on the chassis in some places and its utter pish, flaking already and i haven't even got the thing on the road. Get some primer on it first, you'll not regret it. If I could I'd strip the whole thing and respray it.
Miks15
posted on 22/12/08 at 10:18 PM Reply With Quote
anyone recomend a primer? IS red oxide good primer good for this sort of thing?
Mark Allanson
posted on 22/12/08 at 10:21 PM Reply With Quote
I have the advantage of being a bodyshop manager and need an understanding of paint for my job. I almost didn't answer this thread because it will probably make me sound like a nasty old grump, only one of the replies contains any valid content, and that is the link to chassis paint - I cannot think why they call it that
Hammerite is good paint for applying to heavily rusted items as it has no self etching properties of its own and relies on the rough surface of corroded metal to bind with the surface. It has added silicone to give the hammered finish which will contaminate your spray gun forever (any future coat of any paint will have 'fisheyes' of silicone - it only needs a few microgrammes.) If you add white spirit to Hammerite it will break down the binders - they have their own specialised thinners which you can buy.
David zinc 182 is not cellulose based, neither is satin black unless it is over 20 years old.
Heavy paint - not even going to go there!
Synthetic is a good paint to use but is the exact opposite of cellulose
There - everybody hate me now
mark chandler
I,ll second that, never found hammerite that good, its so hard it chips. If you want locost get a can of dulux oil based black paint from B&Q, it will take a while to go off but is resistant to knocks.
Miks15
posted on 22/12/08 at 10:28 PM Reply With Quote
well mark what combination or what paint would you recomend
Im looking for blue paint aswell so need to be available in blue
Mark Allanson
posted on 22/12/08 at 10:47 PM Reply With Quote
How much do you want to spend - the ultimate is a shot blast then a chromate etch then a wet on wet primer followed by a 2K solid colour but that would need a lot of pro equipment and costs.
The cheapest is a rubbed down chassis with 80g production paper followed by 2 roller coats of zinc 182 (get the special 'light' variety) followed by non drip gloss with a gloss roller, use enough coats to give complete opacity. Domestic gloss (quality brand) is actually quite a good option, although automotive synthetic would be more resilliant.
Miks15
posted on 22/12/08 at 10:54 PM Reply With Quote
What are your toughts on red oxide primer?Dad has a fair bit lying around and it would be free.
Would this be good enough to use then a gloss coat on top?
mark chandler
posted on 22/12/08 at 11:00 PM Reply With Quote
Pop down your local agricultural suppliers, they do stuff called Teamac. It comes in colours such as:
Ford blue
JCB yellow
Masey Furguson grey
Not the cheapest but sticks like @@@@ to a blanket and can take a whack.
Brush or spray, with a good finish.
I painted the chassis of my landrover with this, used to get beaten to bits when racing, the stones soon chipped off hammerite, this stuff was untouched. Worth the extra dosh IMHO.
Regards Mark
Mark Allanson
posted on 22/12/08 at 11:10 PM Reply With Quote
Transport enamel, I had forgotten about that - another trade name is Tekaloid - good stuff
MikeR
posted on 22/12/08 at 11:35 PM Reply With Quote
So the summary is, rub down (maybe with angry grinder and wire brush aka "the tool" ).
Coat with zinc based primer
Finish with either...
Transport Enamel
Or
Tekaloid
or
Chassis Paint
or
Decent Gloss paint
If you where to add the epoxy paint into the equation mark what sort of order (ignore price) would you put the top / final coat paints?
(i don't hate you mark, i like to listen to someone who has 'work' experience as opposed to 'hobby' experience. Just don't be upset if i completely ignore you as for some stupid reason i decide i know better!)
(usually i find out i'm wrong, but i seem to like to learn by making mistakes)
Mr Whippy
posted on 23/12/08 at 08:09 AM Reply With Quote
you could buy some of the marine hull paints, they tend to be very resistant to corrosion and salt and there's tough zinc primers too.
PAULD
posted on 23/12/08 at 09:30 AM Reply With Quote
Chassis paint
I used hammerite and although it has its uses chassis paint isn't one of them. It has chipped badly and I have spent some time under the car replacing it.
steve m
posted on 23/12/08 at 09:44 AM Reply With Quote
I used a zinc primer, and then hammerrite
to be honest IMHO hammerite is crap, it chips very easily, and on my car now the whole chssis realy needs to be redone
Yet my last project , Covin Porshe, i was advised to use normal house hold black gloss, over a good zinc primer,
I havent seen the Covin for about 2 years, but when i did the chassis still looked like the day i painted it
Mr Whippy
posted on 23/12/08 at 09:54 AM Reply With Quote
I’ve used spray smoothrite on the bluebirds suspension components and its worked very well but need quite a few coats about 10 minutes apart while hung over an electric fire, the gloss is quite superb and its went very hard and tough. They were then left to cure in the house for a week before refitting. Can’t say how well it would last in the real world as the cars back in its plastic bag till the spring but they sure look nice
dhutch
posted on 23/12/08 at 10:45 AM Reply With Quote
Been reading this thread with interest.
- I have a 17 yo seven which needs something doing in terms of chassis paint.
By best thought so far is to cant the car over to about 45 degrees (for access) then presurewash it all and rub down as best i can (pannels in place) and then see what im left with.
- If its mainly down to steel, then clearly i need primer/undercoat followed by something suitable.
- Then, or if its mainly actaully sound paint still, a suitable top coat. That is compatable with what went before.
On the boat (narrowboat) we have:
Blast primer (very thin, red coloured, two pack paint)
Zinc Epoxy (high built zinc rich epoxy based undercoat)
Then eather a two pack Acryilic Urethene for the topsides, or a one pot Underwater Vinal Primer for the blacking.
My favoured job, which is how i would start on a new chassis, would proberbly be the blast back to bright, then use the blast primer, followed by the zinc undercoat suitably thined to reduce build a little, then a top coat of choice. Could be one of the above, else proberbly the acrylicurethene as it have loads. (the blacking would be fantasic, but for future, is compatable with just about nothing, and its thick and heavy)
Failing that, ive heard a lot about Por15 and an keen to have a play!
Daniel
[Edited on 23/12/2008 by dhutch]
<<  1    2  >>
New Topic New Reply
