<<  1    2  >>
New Topic New Reply
Author: Subject: welding a steel floor
Miks15
posted on 25/12/08 at 09:54 PM Reply With Quote
Im using a steel floor on my car (please no cut it out and use an ali floor cmments)
and have just tacked it on so far, i was just wondering how much i need to weld it on? out and inside chassis rails? how much weld then how much gap etc?
What have others done?
Mikkel
blakep82
posted on 25/12/08 at 09:58 PM Reply With Quote
lol i'll probably get shot down for this one, someone will say its not good enough etc, however...
on my car, remember this is professionally built by SHP for racing, the chassis link bar brackets are stitch welded, i think its about a half inch weld, half inch gap, half inch weld etc. so maybe that gives you a bit of a guide? i'll measure the proper gaps later for you
________________________
big_wasa
posted on 25/12/08 at 10:00 PM Reply With Quote
I bonded and rivetted my steel floor no boing here
Miks15
posted on 25/12/08 at 10:07 PM Reply With Quote
considered but weldings more fun and quicker, plus im already tacked on
chris_smith
posted on 25/12/08 at 10:21 PM Reply With Quote
mines a stuart taylor chassis and is stitch welded about inch welds with about 1 to 2 inch gaps iirc can get pics tomorrow if ya like let me know
chris
Miks15
posted on 25/12/08 at 10:51 PM Reply With Quote
is that welded on both sides of the chassis rails? or just on one side?
AdrianH
posted on 25/12/08 at 10:58 PM Reply With Quote
It would be interesting to get a comment from an MOT inspector if there are any on here. I had it in mind that floor panels had to be fully welded all round when repaired so would have thought the same for original floor. How this is considered when the floor is bonded and riveted I am not sure!
I could be talking complete rubbish and the wrong idea, but will soon be doing the floor on my build and was also doing steel.
Adrian
Why do I have to make the tools to finish the job? More time then money.
Humbug
posted on 25/12/08 at 11:00 PM Reply With Quote
Adrian
Maybe only applies to monocoques?
blakep82
posted on 25/12/08 at 11:06 PM Reply With Quote
i think seam welding for MOT only relates to 'repairs' bearing in mind a lot of cars are spot welded. i'm pretty sure a mot inspector told me that a few months back. he was also talking about cars with body kits where the whole sill is hidden, they could be rotten underneath and they're not allowed to check. all pretty grey really
i reckon stitch welding is the best as far as heat distortion is concerned. weld an inch on one, move to the other side of the car, do an inch there, etc.
mark chandler
posted on 25/12/08 at 11:37 PM Reply With Quote
Be warned if you do decide to fully weld take your time over it, I did this as my first attempt, tacked in place, then back filled, when I had finished and stood back to admire my handywork the floor was buckled
In the end I cut it out and replaced with ali bonded and rivited.
It was a complete PITA, especially as I worked from side to side to minimise heat distortion.
Regards Mark
[Edited on 25/12/08 by mark chandler]
Simon
posted on 26/12/08 at 02:31 AM Reply With Quote
As Mark says, mine too is fully welded, bit here, bit there, but it still warped. Welded all the way round the outside, with plug welds on tunnel/floor joins
Might work if you can restrict the heat to a very small area (by keeping the panel side of the weld cool - with a wet rag perhaps).
Still, at least the low points afford some sort of sensible drainage options - like drilling a hole in them
Simon
madteg
posted on 26/12/08 at 09:54 AM Reply With Quote
I drilled holes in floor 50mm apart and puddle welded them that way it will not bow. If you stay away from welding the corner of the box section it will not pull as the heat is not going up the side of the box, hope this makes sense. Also the floor does not have to be fully welded as its not part of the chassis
scutter
posted on 26/12/08 at 10:59 AM Reply With Quote
On my first chassis I stitched it as a friend who use to work for Louts back in the day said if you were unlucky enough to have a weld break the the max it could unzip was 2 gaps long.
Hope that made sense, Dan.
Bigheppy
posted on 26/12/08 at 11:13 AM Reply With Quote
link
This is how I did the floor on my new project. Its made from a central heating radiator seam welded with no distortion and very strong
When I cut the radiator to size it was too heavy so I separated the front and back skin by drilling/grinding the spot welds.
[Edited on 26/12/08 by Bigheppy]
posted on 26/12/08 at 11:52 AM Reply With Quote
Puddle welding would be the "normal" ;-) way of doing it.
kb58
posted on 27/12/08 at 03:23 AM Reply With Quote
If you stitch-weld or puddle-weld, either way it seems like you're going to end up with large unpainted areas that will rust.
Has anyone tried brazing the floor on? In fact, why can't you solder it on, really. Seems like the lower heat might give a flatter floor.
Then there's true spot-welding...
[Edited on 12/27/08 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
JC
posted on 27/12/08 at 05:34 PM Reply With Quote
I haven't decided how to attach my steel floor yet, however, I planned to use 'weld-through' primer to avoid the rust issue. Any thoughts?
blakep82
posted on 27/12/08 at 05:45 PM Reply With Quote
I'd thought about this too. decided that a good few coats of paint would fill the gaps and stop any problems. or what about using some epoxy resin, or seam sealer round the edges?
Echidna
posted on 27/12/08 at 06:15 PM Reply With Quote
I think that Epoxy resin alone will be rather brittle for the application.
kitCARBON is the new carbon composite parts company specialising in kitcar parts. We can make parts to order in carbon, carbon/kevlar, kevlar, texalium and more!
For any question, just U2U or email me at
theodragonas@gmail.com
blakep82
posted on 27/12/08 at 06:20 PM Reply With Quote
noooo, i mean stitch welding, then smearing expoxy resin over the whole thing to fill the gaps and stop water getting between the panels. the weld holding everything together, and the resin just to water seal it
Echidna
posted on 27/12/08 at 06:23 PM Reply With Quote
That's OK then!
907
posted on 27/12/08 at 07:40 PM Reply With Quote
I know zero where paint is concerned but would it work if you over thinned some paint
and ran it in the gaps between the stitches?
Wipe off surplus, let it dry, then paint as normal?
Paul G
posted on 27/12/08 at 07:43 PM Reply With Quote
I stitch-welded, but put seam sealer across - er - the seams. The aim being to stop the water getting into the joint.
AdrianH
posted on 27/12/08 at 09:11 PM Reply With Quote
This is just a thought from reading Bigheapy's post where he used the radiator. It made me think, that rather then putting the floor under the chassis, why not cut it to fit along the inner edge of the chassis rails. Then when it is welded to the inner edge there is no metal that can not be painted. It would mean continuous welds all the way around and on the roadster that is a few metres of it?
Can anyone see a down side?
Adrian
kb58
posted on 28/12/08 at 03:59 AM Reply With Quote
Adrian
You'll be welding a very thin edge onto a thicker corner. The thin edge will melt first and melt back away from the edge. It might work if you're a very good welder using TIG.
<<  1    2  >>
New Topic New Reply
