alistairolsen
| posted on 28/12/08 at 10:57 PM |
Best place for brackets and bush tubes etc?
These used to come up on ebay all the time, but not recently. Where is the cheapest place to get the preformed brackets for welding to the chassis,
bushes, bush tubes, camber adjusters etc?
hellbent345
| posted on 28/12/08 at 11:01 PM |
http://www.3gecomponents.com
they supplied my brackets bushes crushtubes etc, they do them for the haynes roadster but i think the brackets are the same as for the locost
al
[Edited on 28/12/08 by hellbent345]
alistairolsen
| posted on 28/12/08 at 11:16 PM |
cool, bushes look good as do the brackets
No outer tubes for housings there?
Cheers for the info
londonsean69
| posted on 29/12/08 at 10:02 AM |
Email them, they have put a post on the haynes roadster forums about doing the housings seperate
Not a lot of money either when you consider the agro in sourcing the tube, cutting it to length accurately, then grinding down the weld on the
inside.
Wish I had just bought mine
Sean
russbost
| posted on 29/12/08 at 10:56 AM |
I use 10mm bolts rather than 12mm on The Furore F1, if you're happy with 10mm pivots (more than adequate for the job) I can do the whole lot for
substantially less than the 3ge prices & can supply the outer for the bushes/crush tube assembly too. Let me know if of interest & I will work
you out a price.
