stutz
| posted on 4/2/04 at 11:24 PM |
Escort Diff vs. BMW Diff (Same Track Width)
I'm hoping to build a chassis to book dimensions, but want go with a deDion rear suspension setup. I want to avoid shortening driveshafts on a
Sierra diff, and as my current plans for a donor is to use a 318i BMW, I thought I would compare rear track widths. According to www.carfolio.com(I
need to measure to confirm), the BMW rear track is 55.9" (1420mm) as opposed to the escorts 56" (1423mm).
Is it just me, or would this not be a perfect replacement, given the rarity of Escort diffs, and the cheapness of E30 BMW parts.
Regards,
Stephen
GO
| posted on 4/2/04 at 11:42 PM |
Hi Stutz, and welcome to the nut house!
Certainly sounds like a good candidate, definately worth the effort of finding one in a scrappy and measuring up, and looking at how it mounts. I
imagine the mounts wont cause too much of a problem though.
Let us all know your findings if you do look into it!
[Edited on 4/2/2004 by GO]
Metal Hippy
| posted on 4/2/04 at 11:58 PM |
Excellent.
Another potential BMW based car.
Enjoy driving it while I'm still bleeping about talking about stuff on mine.
Cock off or cock on. You choose.
ed_crouch
| posted on 5/2/04 at 08:09 AM |
yeh, the E30 transmission is good. Also, if tyou want to go for mega power, you can replace the diff for an M3 slipperdiff. But they are pretty
expensive.
Only thing im unsure of, though, is how to remove the hubs. Are they just bolt-ons, or are they pressed into the rear legs??
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
theconrodkid
| posted on 5/2/04 at 08:14 AM |
welcome to the mad house,living in harow you are entilted to join the west london mafia,see under events for our next meet this coming sunday
who cares who wins
pass the pork pies
stutz
| posted on 5/2/04 at 08:48 AM |
Hi all,
Thanks for the warm welcome to the forum.
In answer to Ed's question about the hubs, I have attached a picture below. I am hoping to remove the wishbone section, and attach the deDion
tube roughly where the springs are seated. Not sure if this is a good idea though!
More info on the diff can be found at this site and
this site.
Hoping to drop the diff this weekend so will keep you posted.
Later,
Stephen
  E30 Rear Hubs
[Edited on 5/2/04 by stutz]
Stu16v
| posted on 5/2/04 at 06:19 PM |
Interestingly, the BMW driveshafts-or rather-C.V. joint bolt holes line up perfectly with Sierra driveflanges. A bit of useless trivia that may not be
so useless to someone, someday, perhaps someone who is designing or making Dedion tubes and needs a handy bearing carrier......
[Edited on 5/2/04 by Stu16v]
stutz
| posted on 5/2/04 at 06:33 PM |
Does that mean I could use an off the shelf deDion tube like GTS Tuning offers? Does anyone know if they are made to Escort or Sierra width?
ned
| posted on 6/2/04 at 09:43 AM |
Stutz,
Darrens (GTS) is based on the sierra rear end.
HTH
Ned.
beware, I've got yellow skin
TheGecko
| posted on 6/2/04 at 02:51 PM |
Correct me if I'm wrong (you'll have to join the queue though ) but isn't the E30's stud pattern 4x100 whilst the Scrote is
4x108?
The options would appear to be;
- re-stud the BMW hubs to 4x108
- use different wheels front and rear and no spare
- get multifit wheels
- get front uprights that are 4x100 (hint: it's spelt 'Chevette' )
Dominic
(who is using Chevette/Gemini front suspension in his FWD Corolla powered mid-engined beasty)
mackie
| posted on 6/2/04 at 03:08 PM |
stutz, the GTS de dion kit uses Sierra back end and full Sierra track width. However it's suitable for a book width chassis so don't
discount using Ford bits.
Ofcourse if you already have the BMW parts then by all means use them but it could be a challenge.
Stu16v
| posted on 7/2/04 at 07:23 PM |
You could potentially use a BMW diff, mated to Sierra shafts/outer running gear (the bits which would bolt to the dedion), if the diff is the same
size between drive flanges. I believe that the GTS dedion is designed to utilise the complete Sierra running gear without modification-i.e. no
shortening shafts. If the Beemer diff wont fit in the middle, you can always use a Sierra diff too...
What are your plans for the front end? As somebody has already mentioned, Ford and BMW wheel PCD's are different. Not that it makes a huge
problem, but it is handier to try and keep the same wheel fitment on the car.
brianm
| posted on 8/2/04 at 01:44 PM |
quote: Originally posted by stutz
Don't want to pour cold water on your ideas, but in my workshop at the moment is a book dimension rolling chassis, with a M40 318i E30 engine
lying on the floor right beside it, and there's no way that will fit in there. The engine is canted over, and is far to wide.
