New Topic New Reply
Author: Subject: Tidying welds
speedyxjs
posted on 12/2/09 at 05:42 PM Reply With Quote
Tidying welds
How do you go about it? Most of mine look ok but there are a few untidy ones.
MkII
posted on 12/2/09 at 05:49 PM Reply With Quote
best to grind them flat and re-weld .m.
speedyxjs
Alright. Easy enough
posted on 12/2/09 at 05:54 PM Reply With Quote
As long as the weld is ok, why bother? Most of them will never be seen when your car is dressed anyway.
Phil
MkII
posted on 12/2/09 at 05:58 PM Reply With Quote
if there out of sight and your confident they are strong you could leave them be.I'm a welder by trade so prob just fussy. m.
speedyxjs
posted on 12/2/09 at 06:21 PM Reply With Quote
They are strong enough. I had to cut a couple of the untidy ones to fit the gearbox. Worked up a good sweat trying to cut them
posted on 12/2/09 at 06:38 PM Reply With Quote
Plan A is always grind off and re-welds but don't do too often otherwise you can weaken (through thinning) the underlying material.
Here's my plan B for sheddy looking welds:
Skim body filler over the welds, sand them smooth, spray with high build primer, sand, top coat.
The body filler goes into any crevises and generally smooths out the welds.
It also helps make black satin spayed bodywork look more like powder coat by smoothing out the finer detail.
Ninehigh
posted on 12/2/09 at 07:22 PM Reply With Quote
Can't you just sand/grind off the excess? I mean if there's chunks sticking out like a big scab on your leg isn't it just like excess filler in a dent?
norm007
posted on 12/2/09 at 07:32 PM Reply With Quote
You need to lay your hands on some flap discs.
They leave welds as smooth as a babies
MkII
posted on 12/2/09 at 07:36 PM Reply With Quote
(quote)
we arent making a garden gate here guys
those welds are all thats keeping your arse off the road!
Daddylonglegs
posted on 12/2/09 at 07:48 PM Reply With Quote
Totally agree, but DON'T buy the cheapies!
I got one from Machine Mart for £7 odd which I thought was a little steep, but I've used it loads of times and it's only just giving up the ghost.
Bought 2 from Screwfix at £3.50 each and they lasted for about 5 or six welds before they were no better than a cotton wool pad!!
You definitley 'gets what you pays for'
Ninehigh
posted on 12/2/09 at 07:55 PM Reply With Quote
Originally posted by MkII
(quote)
Yeah I just meant trim them a bit... Surely a great big lump sticking up isn't going to keep your arse off the road
mr henderson
posted on 12/2/09 at 08:11 PM Reply With Quote
I'm going to offer a rephrase of that
"You don't get more that you pay for, but you sometimes get less"
In other words, if it's cheap it's probably garbage, if it's dear there's a good chance that it will be good (but it might not be)
John
posted on 12/2/09 at 10:57 PM Reply With Quote
Oooooh loving that flap disc action. Only troube is sometimes it's a bit TOO effective and the bit of metal I'm giving the flap love ends up being a bit marginal.... 1.5mm thick box section quite easily becomes 0mm
MkII
posted on 12/2/09 at 11:14 PM Reply With Quote
originaly posted by ninehigh
the point i was making was that if your weld consists of big lumps sticking up you've got to ask if it was capable of keeping your arse off the road or should you grind off and start again.(I'm not having a go at anybodys ability to weld but in 20 years as a welder I've seen welds fail and you dont want that in a car that is probably going to be driven"enthusiastically" . m.
James
posted on 13/2/09 at 12:33 PM Reply With Quote
Even if there's no danger caused by a weld breaking, it'd be such a pain in the arse to sort a half buried weld in a built car, it's worth getting them right first time.
Summat like inside the tunnel or something. You'd have to strip half the sodding car out to get to it!
James
907
posted on 13/2/09 at 07:10 PM Reply With Quote
Flap discs are used much flatter than you would use a grinding wheel.
A sort of... "not so steep an angle, angle grinder."
Paul G
New Topic New Reply
