Simon
| posted on 9/2/04 at 03:35 PM |
Fuel pipe
Guys and gals
More appropriate to IRS but others may have an idea.
How have you routed your fuel pipe from tank to tunnel - seems a long a tortuous route.
Going across the gap (see pic) doesn't seem safe or SVA'able.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=10000027.jpg
I'm putting mine along rear sub, then parallel to lower w/bone mounting then along rear of rear bulkhead, then into tunnel
Simon
[Edited on 9/2/04 by Simon]
jonti
| posted on 9/2/04 at 05:19 PM |
Unconventional I know and i'm sure someone will probably say I shouldn't have, but I put my tank above the diff.(see pic) which made the
routing somewhat easier
My reasoning also being that it was away from the rear panel and less likely to get damaged if I got rear ended.(oo er missus !)
Boot space is still the same, just a different shape.
[Edited on 9/2/04 by jonti]
OFROK
blueshift
| posted on 9/2/04 at 06:20 PM |
Makes your centre of gravity higher, means you can't have a luggage space.. can't see a problem with a high tank apart from those.
| posted on 9/2/04 at 07:19 PM |
We have routed ours along rear subframe using copper pipe and up into the tunnel near to the diff. Then (for the blade) it's on the correct side
to feed the brute!
That way we don't have to cross the gap to the front...
jonti
| posted on 10/2/04 at 11:54 AM |
I reckon luggage space is better actually, as you can get a bigger suitcase vertically behind the tank than you'd get horizontally above it.
As for C of G.. my fat arse low down should compesate for a few litres of unleaded a bit higher up.
That's not me drivin' in the avatar by the way its my "assistant"
[Edited on 10/2/04 by jonti]
OFROK
Simon
| posted on 10/2/04 at 12:36 PM |
Cheers chaps - long route it is!
Simon
GO
| posted on 10/2/04 at 12:51 PM |
Jonti,
Thats what I'm hoping to do with my fuel tank as well, gonna have to have a close look at the chassis and see what sort of shape/size I can get
in the whilst keeping it as low as poss.
