sgraber
posted on 17/2/04 at 07:12 PM |
Is this rollbar brace mount strong enough?
Can anyone see why this rollbar mount wouldn''t be strong enough?
Rollbar front brace
Rollbar front brace 2
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
posted on 17/2/04 at 07:23 PM |
bollox the bastard comp lost my answer.... ah well...
looks nice steve, however i would try to link the two sides together or triangulate in side the car to prevent them splaying out. Is there any space
behind the seats?
sgraber
posted on 17/2/04 at 07:30 PM |
I could add a 16ga 1" round tube between the bases of the braces...
That wouldn't get in the way of anything.
Thanks, good point.
Steve Graber
TPG
posted on 17/2/04 at 08:16 PM |
....Or pull your 1" tube up from your brace flange to the centre of the bar,Or from one side up to the other.Depends on what looks your
after.Everything else there looks very well.Are you sure you want to brace it any futher?I wouldn't.
..Which was nice..
posted on 17/2/04 at 08:19 PM |
You'll have to do something about replacing that welding clamp though - the inspectors will never allow it...
stephen_gusterson
posted on 17/2/04 at 08:26 PM |
they would if it was covered with rubber or foam
atb
steve
Kitlooney1000
posted on 17/2/04 at 08:37 PM |
i dont think the clamp would stand up too well in a roll either
Alan B
posted on 17/2/04 at 08:39 PM |
Steve it would be marginally better if it could be moved inboard with the tube centre line coinciding with the centre of the rect tube
below....However, I'll bet this not possible for other reasons...
sgraber
posted on 17/2/04 at 08:49 PM |
nooo... I could move it over to the centerline, but I assumed that the additional butress would increase the area of the weld line.
in your suggestion I get this much weld coverage [] , a 1"x2" rectangle. With the butress out one side I get this []= weld coverage. Is it
still better you think to center it on the post and not worry 'bout the additional metal of the butress?
Steve Graber
Alan B
posted on 17/2/04 at 09:14 PM |
Steve, weld length is important but I'd have thought 6" was ample......I'd say a straight loadpath and non-offset joint was more
important in this case.....IMO
[Edited on 17/2/04 by Alan B]
