matt.c
posted on 28/3/09 at 08:35 PM |
ZX9R clock mounting
I need to fit these clocks to this panel about where it sits now. How is the best way ie brackets to fit it? Cant be screwed from the other side if
the sheet so all brackets/mountings willl have to be bonded to the sheet.
[img][/img]
YQUSTA
posted on 28/3/09 at 08:43 PM |
If you unscrew the clocks dont they split in half?
that would be the easy way and how i did my koso clocks
mistergrumpy
posted on 28/3/09 at 08:45 PM |
I just put a bead of mastic around the outer edge on mine and it holds fine. The clocks don't split if you unscrew them by the way.
You've passe your SVA haven't you Matt? I only ask as I failed on the edges doing my clocks like you.
matt.c
posted on 28/3/09 at 08:46 PM |
Need them to fit flush with the outside face.
matt.c
posted on 28/3/09 at 08:48 PM |
Nope all passed ok with a piece of perspecs covering all of it.
ahb
posted on 28/3/09 at 08:57 PM |
I just sikaflexed them to the dash. It's better if you use a packer plate to get them flush at the front.
Hello!
roadrunner
posted on 28/3/09 at 11:02 PM |
I split mine in two Matt, then cut the lip off , cut out the shape in the dash making sure it was a couple of mm under , then just fixed them back
together, but they are not flush fitting. You will find it difficult to get a nice neat finish to your dash cut out to be able to mount them flush.
You could try gluing them.
Brad.
