stevegough
posted on 29/3/09 at 12:24 PM |
P - clipping brake + fuel pipes for SVA
Does anyone know the min distance brake pipes have to be clipped to the chassis - same with fuel lines - is there a min? 'cos I can't find
it in the manual.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
blakep82
| posted on 29/3/09 at 12:46 PM |
every 30cm if i remember right
________________________
Staple balls
| posted on 29/3/09 at 02:28 PM |
Yup, 30cm is the farthest apart the clips can be, but ISTR they're iffy about stuff hitting.
I went for about 8" on my brake lines down the tunnel, with a blob of PU every 4", just to be safe.
stevegough
| posted on 29/3/09 at 03:12 PM |
Thanks for replies, guys!
so - 30 cms - any idea on the fuel pipes - is that the same - also, What are ISTR and PU ? (sorry, I'm new to this game!)
Luego Locost C20XE.
tendoshingan
| posted on 29/3/09 at 04:42 PM |
The SVA manual only stipulates that the wiring loom is needed to be secured every 30cm.
I couldn't find any mention in the manual of brake lines or fuel lines. Obviously common sense dictated so I pclipped them every 30 cm too.
Guinness
| posted on 29/3/09 at 04:58 PM |
PU = polyurethane adhesive, usually sikaflex or wurth bond and seal.
ISTR = I seem to recall (internet speak!).
HTH*
Mike
* Hope that helps!
Mark Allanson
| posted on 29/3/09 at 04:59 PM |
If you use P clips, there is a good possibility that the pipes will touch the chassis along the route. Use the proper manufacturer clips, its what
they are designed for and cheap and look soooo professional
stevegough
| posted on 29/3/09 at 05:49 PM |
Many thanks for all your replies - and jargon - busting, too!
Mark - what do the 'proper manufacturer's clips' look like, and who stocks them?
Luego Locost C20XE.
Daddylonglegs
| posted on 30/3/09 at 08:30 AM |
HTH*
Mike
* Hope that helps!
lol!
iank
| posted on 30/3/09 at 09:00 AM |
Rally Design stock them
http://www.rallydesign.co.uk/product_info.php?products_id=9971
Anonymous
Mark Allanson
| posted on 30/3/09 at 06:21 PM |
Best from main dealers, I took this shot to remind me which part numbers and car makes
stevegough
| posted on 30/3/09 at 09:08 PM |
Thanks for the links, guys! those clips are like they use on real cars, aren't they?
Anyway, I hang my head in shame because I had already bought my P clips, and I have today spent a couple of happy hours fixing the brake pipes every 5
inches - maybe over the top, but I wanted "to be sure to be sure" as the irishman wearing two condoms said! (SORRY!)
Want to see some piccys?
[Edited on 30/3/09 by stevegough]
Luego Locost C20XE.
stevegough
| posted on 30/3/09 at 09:11 PM |
Sorry, can't seem to post multiple pics?
Luego Locost C20XE.
stevegough
and another...
Luego Locost C20XE.
stevegough
| posted on 30/3/09 at 09:12 PM |
last one....
Luego Locost C20XE.
