GO
| posted on 23/2/04 at 02:41 PM |
engine mounts
About to start designing my engine mounts...
One thing I've noticed about seven's verses production cars is that the engine mounts on prod cars have the rubbers in a V shape so the
the engine nestles down into the V the rubbers make.
However, on sevens, the rubbers tend to be horizontal. Is that just because it doesnt make much different and its easier (less to make).
I would have thought having the mounts in V shape makes it easier to locate the engine, maybe thats the reason in mass production cars??
Any thoughts fellas?
JAG
| posted on 23/2/04 at 03:33 PM |
The Vee shape damps vibrations in more than one plane (not the aircraft or woodwork sort!).
The simple system preferred by kit car types is just that: simple. I guess reduced engine vibration is not a priority for most kit car folk.
Also; because most kit cars are lighter than the original donor car the original engine mounts are usually too hard to effectively remove the
vibrations.
Hence little effort is put into this particular feature.
Justin
Mark Allanson
| posted on 23/2/04 at 06:16 PM |
Most production car mounts are really soft, especially the V shaped ones. My engine for one would hit the chassis rails, steering column, exhast
mounts stc if it was on sloppy mounts.
I have used landrover mounts, dead cheap, easy to get, easy to mount etc
| posted on 23/2/04 at 10:13 PM |
i like marks. i made mine from a pair of fiesta rubbers, a few 3mm plates, and a couple of chopped up shockers (for round tube!). Looks CRAP but seems
to work ok!
