Author: Subject: WTD: set of bolts for lobros
Xtreme Kermit
posted on 16/4/09 at 08:14 PM Reply With Quote
I'm in the process of building up a new rear axle setup.
Does anyone know where I can buy a set of 24 driveshaft bolts and lock tabs form the sierra lobro joints?
locoR1
posted on 16/4/09 at 08:31 PM Reply With Quote
Got mine from here http://www.namrick.co.uk/ great service delivered really quickly most people i know haven't bothered trying to get the lock tabs just make sure you loctite them in they have a habit of coming loose.
Check out my CB500T Cafe Racer build diary
muzchap
posted on 16/4/09 at 09:34 PM Reply With Quote
Good call Dave
Also - DONT paint the sodding lock tabs - I did, the paint wore through and the driveshaft came loose
Luckily I was doing 20mph in traffic through town at the time - s^&t me up though
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Xtreme Kermit
posted on 17/4/09 at 11:19 AM Reply With Quote
Thanks guys - One problem I have is that I do not have one as a pattern.
Do you know the length/thread diameter details to hand, and the threaded length?
muzchap
posted on 21/4/09 at 05:52 PM Reply With Quote
Hi Mate,
U2U me your address and I'll send 1 down to you - have a few spares kicking around but want to try and keep hold of em - but don't mind sparing one to get you sorted
Or if I get drunk in London after work - I can probably chuck it out onto the platform if I catch the crappy First Capital Connect train - it stops every bloody where!
Murray
[Edited on 21/4/09 by muzchap]
cd.thomson
posted on 22/4/09 at 10:23 AM Reply With Quote
if you find the right part on that website Kermit could you list it on here for future reference? I need a few too.
Craig
NS Dev
posted on 22/4/09 at 09:09 PM Reply With Quote
and for goodness sake don't use torx ones, just use capheads!
And you don't need the "locktabs" even though they are not locktabs. I have fitted more than I could shake an armful of sticks at, to many racing cars, and have yet to have a single bolt come even slightly loose, with nothing other than the bolt!
muzchap
posted on 22/4/09 at 10:16 PM Reply With Quote
Heh - I'd listen to NS Dev guys
I did and mine haven't come loose since getting rid of those alleged lock plates...
Xtreme Kermit
posted on 25/4/09 at 11:05 AM Reply With Quote
Thanks guys, been off the air for a few days.
Ta for the advice. I have been in touch with boys at Quantum and have some bolts in the post.
I will measure them up when they arrive and post the info.
Xtreme Kermit
posted on 26/4/09 at 07:42 PM Reply With Quote
so - they are 12.9 breaking strain 8mm x50mm
socket head bolts.
I have just trial fitted them and (I know you said don't do it...) with the tabs and lock washer (I know - I will leave them out...) they are the ideal length.
Hope that helps.
cd.thomson
posted on 27/4/09 at 09:07 AM Reply With Quote
thanks a lot
Craig
