Author: Subject: warm up enrichment
joscorstjens
posted on 22/5/09 at 12:49 AM Reply With Quote
warm up enrichment
On MS1V3, warm up enrichment seems to work up to lik 70 degC. How can I let up work up to 85 degC?
The mixture gets a bit lean when 70 deg is reached.
tia
BenTyreman
posted on 22/5/09 at 02:24 AM Reply With Quote
The temperature values are hard-coded into the assembly code. They cannot be changed using the tuning software. 70 deg C should be hot enough to represent normal running.
If the mixture is lean for 70 deg C and hotter then multiply the entire VE table by X percent and divide the other warmup enrichments by X percent.
If the normal running is correct then you will either have to live with it or alter the source code.
omega0684
posted on 22/5/09 at 11:31 AM Reply With Quote
@ 71 degrees the MS switches to running directly from the ve table, so if its running lean at 70 up the values on the ve table at idle in 1 unit increments until your desired AFR is achieved
job done!
