New Topic New Reply
Author: Subject: Choice of tubing for chassis
Badger_McLetcher
posted on 9/6/09 at 03:55 PM Reply With Quote
Right, hopefully my last post on my chassis design before its completed!
I was hoping to build this chassis out of 30mm sq 1.6mm thickness tube, I can only find one place that'll sell that, it's bright drawn (which means warpage) and would cost a LOT to buy in...
So I have three options:
1) 30x30x2.5mm tube at £15.30 per 7.5m (+vat)
2) 25x25x2 tube at £10 per 7.6m (+vat)
3) 1.5"x1.5"x16 or 14swg tube at £16.90 per 6.1 m (+vat)
Now I want to build this car to handle 1000bhp (not saying I'm going to get to that figure at all, but it's nice to have a rigid test bed!) but even so option 1 seems a bit overkill to me...
What're peoples opinions on this? I would post up a pick of the rough chassis design, but my CAD program is playing silly buggers...
omega0684
posted on 9/6/09 at 04:15 PM Reply With Quote
what engine are you planning to put in it? it will have to be some monster to get you up near 1000bhp!
option 2 is my guess
blakep82
posted on 9/6/09 at 04:19 PM Reply With Quote
i say 2 as well, although 3 looks tempting.
my chassis is 2" round tube, i don't know, 25mm always looks a bit too weedy to me. and the 2.5 mm wall on number 1 is far too thick.
given the options there, 2.
________________________
chris_smith
posted on 9/6/09 at 05:20 PM Reply With Quote
where abouts are you?
have you tried hilmar tubes? or hub le bas? or hall & pickles?
they all do square tube
chris
Badger_McLetcher
posted on 9/6/09 at 07:44 PM Reply With Quote
omega0684, the lump is a 1uz-fe 4l V8. I know I can get 500 out of it with minimal work, but want to leave myself some room for future development!
I'm located in South Bristol, so all those companies are quite a way from me, but thanks for the advice, will ring and see about delivery.
mark chandler
posted on 9/6/09 at 08:49 PM Reply With Quote
Why not just make the lower frame out of the heavy stuff, and 1" 16swg tube for the top.
It’s the triangles that make it rigid, not the size of the tube, no reason not to mix it up a bit if you are concerned, the mechanicals are effectively on tougher stuff.
If you cut open commercial chassis then you find additional internal plates where suspension and engines mount.
Theshed
posted on 11/6/09 at 07:43 PM Reply With Quote
If you are serious about 1000bhp then forget erw square tube you are into dragster power and should build a chassis to match! I cannot understand why you would worry about say an extra £100 or so if you are intending spending £1000s on a an extra 500bhp.
Have you googled "chassisshop" you can buy serious tube and well made brackets in chrome-moly it would probably double the price of your chassis but in the long run.......
Badger_McLetcher
posted on 11/6/09 at 10:16 PM Reply With Quote
Hmmm interesting website but barring the old square vs round tube debate which we'll not go into, I see little benefit going with the tube sold there. Assuming that's 4130 low alloy steel, there seems to be little benefit in terms of yield strength or shear modulus. Just the complication in welding
Besides I'm not entering this into high level competitions or anything, I just want a sturdy platform for any mad engine building ideas I come up with
Theshed
posted on 12/6/09 at 06:39 PM Reply With Quote
My thinking that you might want to up the quality of the tubing is influenced by the thought that with 1000bhp you will have huge forces getting that power to the wheels. You could use lots of tubes or bigger tubes or better tubes but any which way you will need to tie that engine down!
Badger_McLetcher
posted on 12/6/09 at 07:40 PM Reply With Quote
Hehe very true, projectile engines are not part of my plan!
New Topic New Reply
