| posted on 19/6/09 at 09:33 AM |
Suggestions for keeping chassis strength
Hello knowledgeable chassis peeps.
I am looking at cutting out section of lower rail - the area in red needs to be clear as that is where the starter motor bulge in bellhousing will
go.
The engine mount rests on the rail running crosswise - the yellow one.
How would you suggest I fit rails and/or plates to maintain chassis strength?
I can go 3-D i.e. run rail from bottom to top but the exhasut sits on that side.
[Edited on 19/6/09 by 02GF74]
blakep82
| posted on 19/6/09 at 09:42 AM |
an X shape in there? would that clear enough for the starter?
________________________
westf27
| posted on 19/6/09 at 09:48 AM |
how about this,do sympathise had the same problems with my 27
555
James
| posted on 19/6/09 at 11:08 AM |
Firstly, well done, with that picture, assuming it's an F27 you've solved a question from another thread about an ebay chassis!
As for yours.. just move the whole chassis rail outwards and re-weld it in the corner going straight back. This is how it's done in the Locost
and if it's fine for all those cars it'll be fine for you.
James
- Muhammad Ali
| posted on 19/6/09 at 11:19 AM |
Some pictures of 02GF74s clearance problems in this thread.
clairetoo
| posted on 19/6/09 at 04:08 PM |
James
Thats what I'd do - it's what I've just done to an early Fury chassis , and match's where that tube is on later Fury's .
Its cuz I is blond , innit
Claire xx
Will weld for food......
clairetoo
| posted on 19/6/09 at 04:44 PM |
This is what I did - the new tubes are the shiny ones
  Left side chassis mods
And the other side.....
[img][/img]
Claire xx
