New Topic New Reply
Author: Subject: Engine mount strong enough?
maartenromijn
posted on 18/8/09 at 10:08 PM Reply With Quote
As per title. Made of 4mm steel plates (yes I know this will do) and hollow section 35 x 35 x 2 mm.
For the funny guys: no, it has not been finally welded yet!
Engine support
Engine support
BLOG: http://thunderroad-super7.blogspot.com/
blakep82
posted on 18/8/09 at 10:09 PM Reply With Quote
should be well up to the job when its welded up.
very shiney though, is it just mild steel?
________________________
Staple balls
posted on 18/8/09 at 10:13 PM Reply With Quote
Looks pretty similar to the MK ones, so I'd say they'll be up to the job.
maartenromijn
posted on 18/8/09 at 10:22 PM Reply With Quote
I grinded the hollow section with sandpaper flap disc before it was tag welded. This will save me a lot of time preparing for a layer of paint.
mookaloid
posted on 18/8/09 at 11:57 PM Reply With Quote
one of my MK mounts split at the engine end
Mr Whippy
posted on 19/8/09 at 06:54 AM Reply With Quote
looks fine. I make mine like that but use round tube about 40mm in diameter and first weld a captive nut to the base, then weld the tube round that. Doing this save having a cut out like you have and the rubber mount is just spun on and tightened by hand before bolting the whole thing to the chassis and engine.
New Topic New Reply
