maartenromijn
| posted on 27/8/09 at 07:25 PM |
Zetec and mt75 fit, but.... OH NO!
Have I done it wrong??
The gearbox sticks under the chassis approx 60mm.
  gearbox ground clearance
  ground clearance
I have determined the height as follows. The popular Zetec sump modification seems to be 150mm high. I want the sump sticking out maximum 25mm under
the chassis. So I made the top of the ally sump to be 125 mm above level.
Now it seems that the mt75 is sticking out approx 60mm. Since the lower bolts from sump to gearbox don't line up anyway, can I shorten the
gearbox as well??
BLOG: http://thunderroad-super7.blogspot.com/
big_wasa
| posted on 27/8/09 at 07:35 PM |
Ive choped mine down, but I have bought a spare incase I bugger it
maartenromijn
| posted on 27/8/09 at 07:59 PM |
Cool that you have already solved all the problems that I encounter!
Have you placed your engine at the same height?
Do you only use the 5 bolts that originally fit, or have you made more threaded holes, for example in de modded sump? (don't seem that way from
your picture)
r1_pete
| posted on 27/8/09 at 09:53 PM |
I've only used the 5 bolts, seems most people do, with no problems.
big_wasa
| posted on 28/8/09 at 04:11 PM |
Yep just the five bolts. Sump is ~165mm and the bell housing is now about the same as the sump.
Ive got about 15~20mm under the chassis.
The whole lot just fits under my gts Bodywork but I had to get the engine as far back as I could.
big_wasa
| posted on 28/8/09 at 04:14 PM |
pic
