New Topic New Reply
Author: Subject: wider front end - is this ok
luke
posted on 8/9/09 at 12:05 PM Reply With Quote
i ordered lazer cut wishbone brackets and have now discovered they are actually made up to the roadster brackets spec meaning they are slightly taller.
ive tacked on the two for the bottom wishbone and its pushed the bottom wishbone out by 16mm.
now is it gna make it a pain to align the top two correctly? and will it cause me any other issues? i know ill have the make the steering rack extensions slightly longer.
ta,
luke
Ninehigh
posted on 12/9/09 at 06:06 AM Reply With Quote
Is it possible to extend the steering rack? Iirc you're not supposed to weld bits onto it..
New Topic New Reply
