omega0684
posted on 21/9/09 at 01:39 PM |
F**King BIG Bo**ocks!
stripped the bottom end of the pinto this morning so that i could do the honing (which all went well) and then inspected the crank main bearing and
one of them has a crack in it! i measured the crank and it measures 56.98mm, consulting the oracle of Haynes its has standard crank width so is it a
case of just buying and fitting a new set of bearings?
would these be ok
ebay linky
Alex
[Edited on 21/9/09 by omega0684]
lotusmadandy
posted on 21/9/09 at 01:51 PM |
Yup.. will be fine as long as the crank
isn't damaged.
Mr Whippy
posted on 21/9/09 at 01:53 PM |
just be glad you spotted it now
prawnabie
Can't see the auction because at work, but the link says big end bearings and you say the mains are cracked?
Thinking about it
posted on 21/9/09 at 02:01 PM |
He must be talking mains as big end is 51.98 - 52.00mm
posted on 21/9/09 at 02:50 PM |
Time for that zetec?
omega0684
posted on 21/9/09 at 02:54 PM |
no NOT the big end bearings of the conrod, i mean the main crank bearings that hold the crank in the block.
above link corrected
here
flak monkey
posted on 21/9/09 at 02:57 PM |
Yep, the auction is for big end bearings
You need mains.
Sera
http://www.motosera.com
posted on 21/9/09 at 04:28 PM |
I would add a 'BIG' between the two words in your thread title (preferable in bold)!
The initial statement just doesn't convey the seriousness of your predicament!
omega0684
posted on 21/9/09 at 05:29 PM |
just for scootz, title amended!
RichardK
posted on 21/9/09 at 06:12 PM |
lucky bugg3r if you ask me, noticing now and not finding out the noisy way!
Rich
Gallery updated 11/01/2011
posted on 21/9/09 at 07:01 PM |
I thought from the title you were boasting!
omega0684
posted on 21/9/09 at 08:20 PM |
i am !
posted on 22/9/09 at 06:29 AM |
Perfect.. thanks!
jpindy3
posted on 22/9/09 at 08:52 PM |
hi alex,
i take it you would have fitted new mains anyway,
'if there was no crack'
