arrow-engineering
| posted on 3/10/09 at 04:26 PM |
stuart taylor/aries irs question
hi there, can someone who has a stuart taylor/aries locost give me a few measurements on the main rails that take the rear suspension.
i want to know how far apart the bottom rails are, how far apart the top rails are and how far away the top and bottom rails are from each other.
if poss centre of pick ups to centre of pick ups on rails and centre to centre of rails on height.
thanks in advance, did i make any sense at all?
mark chandler
| posted on 3/10/09 at 09:03 PM |
Bit confused by the question as I thought these were live axle chassis.
That aside you will need to locate the Sierra diff so the pinion is central, the diff is however wider on the crownwheel side and the shafts are
handed.
Then make up your wishbone locations, I made all mine to suit, as a scratch build, if you are buying in then you will need to find out the
measurements from the bone supplier.
Regards Mark
arrow-engineering
| posted on 27/7/10 at 08:15 PM |
irs
i think in the s.t. the diff is offset so the driveshafts end up the same length
