Nitrogeno25
posted on 2/12/09 at 05:20 PM |
wishbone tubes
I know it's been discused many times, but I can get enough info about tube size.
Where I live I can only get 21.3mm seamless tubes (2.4mm wall). This is the closest size to 1".
What do you think?
Cousin Cleotis
| posted on 2/12/09 at 05:55 PM |
How much is it? You may be able to get a more suitable size mail order.
Where are you?
Paul
[Edited on 2/12/09 by Cousin Cleotis]
designer
| posted on 2/12/09 at 06:18 PM |
It's always best to tell where you are!
How can we help you otherwise?
Nitrogeno25
| posted on 2/12/09 at 06:53 PM |
I am from Uruguay, south america
mark chandler
| posted on 2/12/09 at 09:09 PM |
Got any landrover breakers? I used the steering drag link tube for my lower bones, the stuff you have above will be fine for the top bones.
Regards Mark
907
| posted on 2/12/09 at 09:43 PM |
I re-bushed a catering van chassis the other day.
I've seen thicker drinking straws.
It made my w/b's & bushes look like something off a 4X4.
Paul G
mark chandler
| posted on 2/12/09 at 10:04 PM |
On the same subject, if you point the shock at the centre of the ball joint rather than 1/3rd of the way along you can reduce the tube size as it
no-longer acting as a lever.
Do this and use the tube you have, just have a decent gussett to spread the load at the end.
[Edited on 2/12/09 by mark chandler]
Chippy
| posted on 2/12/09 at 10:42 PM |
If you can find a local firm that does hydraulic stuff, they always use seamlesss tube due to the pressures involved. HTH Ray
blakep82
| posted on 2/12/09 at 11:48 PM |
i got 25mm seamless easy enough at metal supermarkets
________________________
Nitrogeno25
| posted on 14/12/09 at 08:12 PM |
What I can get in 21.3mm is called schedule 40. Does this stuff is strong enough?
Or it could be 26.7mm o.d. but I think it's overkill.
Thank you very much.
