Author: Subject: triggerwheel fixing
joscorstjens
posted on 6/12/09 at 11:52 PM Reply With Quote
triggerwheel fixing
I just installed a triggerwheel to the crank of my pinto. In order to avoid slipping, I put a bolt in the pulley. Do I need to add 3 more bolts to keep a balanced crank or is the weigth too low to be relevant?
tia
ashg
posted on 7/12/09 at 01:16 AM Reply With Quote
when spinning at 6000rpm i would say you need to balance it.
this is how i mounted mine
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mcerd1
posted on 7/12/09 at 11:35 AM Reply With Quote
I made mine as symmetrical as possible and then got it balanced at the engine builders (mines a custom alloy pulley and I was getting the whole bottom end done anyway)
he hardly had to take anything off it to balance it, aparently it was almost spot on
[Edited on 7/12/09 by mcerd1]
cd.thomson
posted on 7/12/09 at 11:37 AM Reply With Quote
What have I told you about posting porn on these forums mcerd1
Craig
mcerd1
posted on 7/12/09 at 01:16 PM Reply With Quote
don't worry it'll all be hidden on the car once its built, just like all the other shinny bits....
that pulley's now in stealth black (hard anodised)
and then I've got the std. belt cover to hide some of it to
dhutch
posted on 7/12/09 at 01:59 PM Reply With Quote
To ballence, you would only need to add one more bolt, one each side. Not four (of six, or eight...)
tia
