samsouth
| posted on 11/12/09 at 04:20 PM |
Steering support question
Hi, i'm new to the site. I'm most of the way through the chassis build using the newer sierra book, and need a couple of measurements
please.
I can't find the spacing of the two CP15 brackets along the steering wheel support frame(SS2 maybe, i don't have the book on me), and i
don't have the donor car yet to size it up?
thanks
James
| posted on 11/12/09 at 04:29 PM |
Hi Sam,
Welcome to the site.
Always worth putting your approximate location in your profile as there may be builders local to you who can help.
Also, did you know there's a dedicated Haynes forum for those building this car?
James
- Muhammad Ali
RAYLEE29
| posted on 11/12/09 at 04:36 PM |
There is no Dim in the book as the columns are apparently different from car to car
Best bet is to get your column and measure the spacing on that and fit the brackets accordingly
haynes forum here
Ray
mark chandler
| posted on 11/12/09 at 05:06 PM |
Its one of the later things to do, when you have the seat and pedals in place hold the wheel where it most suits you and make backets up.
Mine drops down between clutch and brake pedal as I like a bit of an angle others have them more horizontal.
Regards Mark
Regards Mark
samsouth
| posted on 12/12/09 at 10:34 AM |
Thanks for the welcome and your help, i'll just be patient then. cheers for the link also! lots of info there to!
