Author: Subject: Wind Deflectors
tigerzetec
posted on 14/3/10 at 06:29 PM Reply With Quote
Wind Deflectors
Have made a pair of these for the Tiger to see if the wind will ease off on the old ears.
Also, if it don't, will make a good stone deflector for when i take my 8 year old son out for a blast. The car will be back on the road in april, so will have to wait and see........ Rescued attachment Wind Deflectors.jpg
TigerB6 Paul
posted on 14/3/10 at 06:33 PM Reply With Quote
If you really want to cut down on the buffeting then you will need to extend down the sides of the scuttle. I speak from experience of having done the same job a few years ago.
tigerzetec
posted on 14/3/10 at 07:09 PM Reply With Quote
Ok thanks for the info. I must admit, i have seen something like what you describe, and as you say, this is what is needed, but it needs to look reasonable and i don't think it would look good, if i extend down the sides of the scuttle.
I may add trim to them yet as well.
I remember the buffeting reducing enough when i put my hand where the deflectors are, so fingers crossed.
As Tesco says ' Every little Helps' Lol
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 14/3/10 at 07:39 PM Reply With Quote
Thats true but remember your hand is connected to your arm which will be running near the side of the scuttle. But indeed the deflectors should make a notable difference
mangogrooveworkshop
posted on 14/3/10 at 08:37 PM Reply With Quote
Hope you have used poly carb
and not Block and Quade perspex.
look good
