Steve Lovelock
posted on 11/5/04 at 03:11 PM |
Chassis mods for Vauxhall 16V
Hello,
I am interested to know what modifications are required to a book built chassis to fit a Vauxhall 16V engine?
Does anybody have accurate dimensions I could use?
Are there any major issues with building a locost for the 16V?
Mr G
posted on 11/5/04 at 03:18 PM |
No modifications went into my mates (billys) chassis. Its a book luego. 16v (westfield engine mounts) was mated to a carlton/senator getrag box which
had a bit of the cast bellhousing cut out to clear the start of the tunnel.
Sump was the original alloy one re-welded shallower into a gullwing design.
As a guide to where the engine sits the front lip on the cam cover (timing cover removed) is up against the rear edge of the nosecone. The bonnet sits
on with no modifications.
![](/galpreviews/Picture 0378.jpg) ![20XE](/gallery/Picture 0378.jpg) 20XE
Ground clearance is'nt fantastic though - remote oil filter fitted to help but the limiting factor is the bottom of the vauxhall box which is
quite low - the same as the bottom of the modified sump.
HTH
G
[Edited on 11/5/04 by Mr G]
ned
posted on 11/5/04 at 03:21 PM |
haven't fitted my engine yet, but am not making any mods to fit the engine in. I've bought a shallow alloy sump (yes, i know the expensive
one) which fits nicely. I have an adapter bellhousing ot the type9, though might be changing this to fit he t5 box I've since bought..
Ned.
beware, I've got yellow skin
James
posted on 11/5/04 at 05:11 PM |
"My mate Billy had a ..."
Sorry! Couldn't help it!
James
Mr G
posted on 11/5/04 at 06:38 PM |
[comingtoamerica]
Stay off the drugs son
[/comingtoamerica]
![](/images//smilies/bigsmile.gif)
