<<  1    2  >>
New Topic New Reply
Author: Subject: Tips to help new builders ?
Jon Ison
posted on 28/4/10 at 09:09 PM Reply With Quote
Was chatting in garage earlier with Bryn of Allyfab fame, he came over with a bonnet template to make sure the "bulge" was in the correct place and we got to talking what would you do different ?
Tip number one.
Consider building the chassis with higher top rails, most engine installations require a cut out or bulge if built to book dimensions.
Tip number two............ over to you guys.
SeanStone
posted on 28/4/10 at 09:24 PM Reply With Quote
Makes sure your tunnel is wide enough if you've got a big gearbox going in
boggle
posted on 28/4/10 at 09:33 PM Reply With Quote
tip 3.....
dont fit a pinto then decide to go bec!!!
u2u me for details
omega0684
posted on 28/4/10 at 09:34 PM Reply With Quote
buy one dont build one! but then where is the fun in that!
andylancaster3000
posted on 28/4/10 at 09:41 PM Reply With Quote
I might question this one!Tip number one. Consider building the chassis with higher top rails, most engine installations require a cut out or bulge if built to book dimensions.
I reckon you have to be careful with this one. I reckon, though biased, the book Locost is one of the best proportioned seven replicas about even with a bonnet buldge, they can very easily be spoiled I reckon Just a consideration! (and an odd one for me being 'form before function' )
[Edited on 28/4/10 by andylancaster3000]
Sprytny
posted on 28/4/10 at 09:49 PM Reply With Quote
Consider the list of all the list of all test failures, and take this into account when building the a car...
Mark G
posted on 28/4/10 at 09:53 PM Reply With Quote
Make sure you have plenty of consumables at hand during the build. You never know when you might need your next nut, bolt, rivet or length of wire etc...
OX
posted on 28/4/10 at 09:55 PM Reply With Quote
When your putting it on ask your self ' how easy can i take it back off once the car is fully built'
James
posted on 28/4/10 at 10:45 PM Reply With Quote
Agreed- sorry Jon!
I added 1" to the top of my car.... really regret this now and have been considering how to remove it with minimal hassle!
A bulge would look nicer.
James
alistairolsen
posted on 29/4/10 at 06:41 AM Reply With Quote
I built the outer chassis which is limited by the bodywork, but wont build the tunnel or engine support rails until the engine and gearbox are in place. To my mind a must if you're going supersize on the engine!
Dont underestimate the time spent making and fitting brackets, fitting my seats took as long as the whole front end of the chassis frame!
My Build Thread
iank
posted on 29/4/10 at 06:50 AM Reply With Quote
Agreed- sorry Jon!
James
Sadly you can't alter the chassis, to that extent, without an IVA.
Anonymous
iank
posted on 29/4/10 at 06:52 AM Reply With Quote
Tip take some time to get your build environment tidy and organised. If possible make sure you have enough room to walk around the car comfortably without having to shuffle sideways.
Anonymous
daviep
posted on 29/4/10 at 06:54 AM Reply With Quote
Agreed- sorry Jon!
James
Of course you can, nobody will ever know and we won't tell on you
fesycresy
posted on 29/4/10 at 07:16 AM Reply With Quote
Make sure your tunnel is as narrow as possible for a nice big footwell.
CEC's need not apply
posted on 29/4/10 at 07:26 AM Reply With Quote
Try and think OEM as much as possible when building.....
tegwin
posted on 29/4/10 at 08:22 AM Reply With Quote
Measure thrice, check twice and cut once!
Take time over everything you do on the car, you dont want to rush to get a piece finished only for it to bug you for ages because its not quite as perfect as you could have managed!!
www.verticalhorizonsmedia.tv
Jon Ison
posted on 29/4/10 at 08:34 AM Reply With Quote
mmmmmmmmm, healthy debate, maybe I will like the bulge better than I would have higher top rails ?
speedyxjs
posted on 29/4/10 at 09:17 AM Reply With Quote
Originally posted by boggle
tip 3.....
Dont you mean 'dont decide to go BEC'?
posted on 29/4/10 at 09:43 AM Reply With Quote
If you think that you will want a windscreen, but don't want it fitted when doing the IVA, install everything during the build while it's relatively easy. Once it's there and working nicely, take photos, uninstall and pack it all away nicely. Use plastic plugs and things to make it look like you're not intending to fit a screen to keep the tester happy.
DO NOT try installing a screen 4 years later, as I did!
pewe
posted on 29/4/10 at 09:55 AM Reply With Quote
Work on the premise you are going to take one-step forward and two back.....
And when you reach the stage of thinking "Why the b*gggery b*llocks am I doing this?" just remember there are lots of builders out there who've finished and come back with a big idiot grin on their faces after each blat.
Cheers, Pewe
geeksandlies
posted on 29/4/10 at 10:01 AM Reply With Quote
Ensure you have permission from 'er indoors?!?
Ensure you come on here to have the renowned BEC vs CEC debate? (oddly i haven't yet but then i haven't asked the dreaded question only poped up with random ideas after the strike me)
Buy a t-shirt?
Get adopted by a builder on here? (What happened to that thread?)
Research, research, research!
The one who dies with the most toys wins!
Marcus
posted on 29/4/10 at 11:44 AM Reply With Quote
I you're welding your own chassis, BUY all the suspension brackets!!!
I took far too long making all mine from 40mm x 3mm flat stock when I could have been doing other things!!
Marcus
Because kits are for girls!!
eddie99
posted on 29/4/10 at 12:29 PM Reply With Quote
Agreed- sorry Jon!
James
That can only come from an IVA inspector
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
alistairolsen
posted on 29/4/10 at 12:42 PM Reply With Quote
If you have space, dont strip the donor straight away, having non running engines lying for 2+ years is less than ideal!
My Build Thread
iank
posted on 29/4/10 at 01:03 PM Reply With Quote
Agreed- sorry Jon!
James
I wish
I was speaking from a purely legal point of view, since people from VOSA (and presumably the DVLA) have been known to read this forum implying you're going to break their rules means you need to be aware of the risks.
Though it's not quite as obvious as putting an MK onto a dutton V5.
Anonymous
<<  1    2  >>
New Topic New Reply
