PuppiesBalls
posted on 3/5/10 at 08:14 PM |
WELD ON TANK FITTINGS
Good evening Gents,
Im having a fuel tank made at the moment but I cant find anybody who sells weld on tank fitings.
The tank being made from stainless so the fittings need to be stainless too.
Alternativly to weld on fittings I could get threaded elbows like the ones that are used on fuel pumps.
I need 2x90 degree elbows - one 10mm inside diameter & the other 8mm.
Thanks in advance for the help
designer
posted on 3/5/10 at 08:17 PM |
Due to the weight and the thin material used, fuel tanks are usually held by straps.
Welded tabs are realy a no go area as they can crack with fatigue.
RichardK
posted on 3/5/10 at 08:34 PM |
What about these, designed for aircraft so should be ok for automotive use! Down near the
bottom.Linky
Rich
Gallery updated 11/01/2011
hillbillyracer
posted on 3/5/10 at 08:36 PM |
It's more fittings for the pipes is it not rather than brackets to bolts it to the car with?
PuppiesBalls
posted on 3/5/10 at 08:41 PM |
Correct
RichardK
posted on 3/5/10 at 08:45 PM |
Do I win a prize or owt ?
Rich
PuppiesBalls
posted on 3/5/10 at 08:46 PM |
bottom.Linky
Rich
these ones? eek- look abit leaky lol the elbows are going on the bottom of the tank so id prefer a more permanent fitting, Thanks though
[Edited on 3/5/10 by PuppiesBalls]
Fred W B
posted on 4/5/10 at 11:05 AM |
Look for industrial suppliers of dairy fittings, or any pipe fittings place that does stainless. You can weld on ordinary hosetails or threaded
nipples. You can cut them to length first if necessary
Fred W B
kb58
posted on 4/5/10 at 02:57 PM |
Whatever you do, don't use threaded fasteners that have a nut on the back; depending how the tank's constructed, it'll put you in a
spot.
Eventually the fitting will come loose, and once that happens you're done for. The nut on the inside will happily spin forever as you drive
yourself mad...
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
PuppiesBalls
posted on 6/5/10 at 08:29 AM |
Still trying to find some fittings
40inches
posted on 6/5/10 at 08:52 AM |
Anything suitable here?
hughpinder
posted on 6/5/10 at 09:42 AM |
Try
www.allstainlessltd.co.uk
Regards
Hugh
