<<  1    2  >>
New Topic New Reply
Author: Subject: how close?
RedAvon
posted on 18/5/10 at 03:02 PM Reply With Quote
how close?
My petrol tank (with fuel) sits in between the rear box section chassis and i can't get it out without taking off the body.
How close to the fuel tank can i weld brackets onto the chassis rails. I.e. not welding the tank itself but welding onto the rails around it - with a MIG Clarke 151TE?
posted on 18/5/10 at 03:04 PM Reply With Quote
Depends how much life insurance you have Personally I wouldn't fancy it- seen the consequences....
Ben_Copeland
posted on 18/5/10 at 03:05 PM Reply With Quote
Welding and petrol fumes don't mix!
Ben
Locost Map on Google Maps
Enter Your Details Here
jossey
posted on 18/5/10 at 03:09 PM Reply With Quote
owwww fire starter can i come watch :O)
Lars
posted on 18/5/10 at 03:19 PM Reply With Quote
I would suggest draining the tank and filling with water.
It's a pita, but a lot safer
Lars
posted on 18/5/10 at 03:21 PM Reply With Quote
That said how close do you want to weld?
Staple balls
posted on 18/5/10 at 03:22 PM Reply With Quote
Can I watch?
will121
posted on 18/5/10 at 03:23 PM Reply With Quote
how close are you calling close, risk is not always how close you are to the actual steel fabric of the tank (long as no pin holes in it) but how close you are to vapour routes like, filler vents and outlets, mig sparks can travel a few feet in any direction if not shielded with same disastrous results as if 6" away. its a caculation of risk, likelyhood and precautions.
RedAvon
posted on 18/5/10 at 03:24 PM Reply With Quote
The tank is about an inch clear of the frame and i want to weld some small brackets for brake pipes on the box section on the side away from the tank - just dont want to take the body off and the tank out - unless this isnt too bad a job?
Rod Ends
posted on 18/5/10 at 03:42 PM Reply With Quote
... you've got to ask yourself one question: Do I feel lucky? Well, do ya, punk?
AdamR
posted on 18/5/10 at 03:53 PM Reply With Quote
Easy. Use rivets.
Staple balls
posted on 18/5/10 at 03:54 PM Reply With Quote
Lars
posted on 18/5/10 at 04:00 PM Reply With Quote
very good
mangogrooveworkshop
posted on 18/5/10 at 04:10 PM Reply With Quote
Oh yes thats fantastic
bi22le
posted on 18/5/10 at 05:00 PM Reply With Quote
As said before. Its all about the vapour trail.
Empty tank (I wouldnt fill it with water) and extend any outlets away from the area. Do it in a ventilated area.
Oh and have a fire extinguisher on hand!
Goodluck
Please read my ring story:
posted on 18/5/10 at 05:27 PM Reply With Quote
How close?
This is close:
http://news.bbc.co.uk/1/hi/8683750.stm
Paul TigerB6
posted on 18/5/10 at 06:13 PM Reply With Quote
I cant see you'd have a problem to be honest if you aren't welding right by a fuel outlet. You have an inch between the tank and chassis rail - so why not put a wooden board between the two as an insulating shield??
se7en
posted on 18/5/10 at 06:47 PM Reply With Quote
Real quality
kb58
posted on 18/5/10 at 08:11 PM Reply With Quote
I was going to ask when you're going to do it, but since I'm in California, I figure I'll hear it go off...
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
whitestu
posted on 18/5/10 at 08:36 PM Reply With Quote
I remember welding my brothers Alfasud near to the petrol tank when I was about 18.
We had the fuel filler disconnected to gain access, with my brother plugging the filler with damp cloths.
I finished the weld to see my bother chatting with a neighbour and flames coming out of the filler pipe!
Didn't blow up though
[Edited on 18/5/10 by whitestu]
richard
posted on 18/5/10 at 09:09 PM Reply With Quote
can you not drill and bolt / rivet/ rivnut/ clamp the brackets you need to fit instead for now until you ever have the body off.
Rich
RedAvon
posted on 18/5/10 at 09:42 PM Reply With Quote
is it ok to rivet/bolt the brake brackets to support the copper pipe/flexi hose onto the chassis for IVA tho' ?
Wumps
posted on 18/5/10 at 09:59 PM Reply With Quote
This is what I intended to do, surely seen as secure enough.
40inches
posted on 19/5/10 at 07:39 AM Reply With Quote
P clips etc: are the usual method
Brake line
Brake line
RedAvon
posted on 19/5/10 at 03:52 PM Reply With Quote
i mean these bits - pic of someone elses car - mine dont have any welded to the chassis where the flexis connect to the copper through a bracket - will anything except welding pass IVA?
<<  1    2  >>
New Topic New Reply
