Glan Noye
| posted on 21/5/04 at 11:42 PM |
Engine mounting
Over the weekend I am going to put the weight of my engine on to my chassis for the first time. I don't want to create any local stress
areas.How big should I make the mounting plates?Thanks Glan
| posted on 22/5/04 at 12:49 PM |
What ever size you make the plates they still put a big bending load on the lower members what is required is an extra tube at each side to take
the loads to a vertex.
With a spaceframe the loads should always be at vertexes where 3+ tubes meet as the tubes themselves have no strength/stiffness in bending .
It isn't always possible but the loads should be fed in as close as possible to the corners of bays.
jcduroc
| posted on 24/5/04 at 11:05 PM |
the loads to a vertex...
Might be like this (BT?)
Make an apex at the side bay and put an extra tube as this one.
JCM
jcduroc
| posted on 24/5/04 at 11:09 PM |
And then weld the plate to support the mountings.
JCM
