MikeR
| posted on 29/6/10 at 11:40 AM |
Standard sizes of steel box section around 45mm??
I'm after some box section, around 2 or 2.5mm wall.
I wanted it to be around 40 to 45mm box and i only need 1.5meters .
When i called metal supermarket the only box they did was 1.5mm.
Is there somewhere that lists standard sizes?
jossey
| posted on 29/6/10 at 11:44 AM |
http://www.offroaders.com/tech/steel-gauge-thickness.htm
it works in gauge size not mm.
16 gauge is normal size for chassis i think.
see link may help you.
david j
MikeR
| posted on 29/6/10 at 11:45 AM |
Cheers - its not for the chassis.
Link is useful but i'm after what sizes of box are produced as standard.
JeffHs
| posted on 29/6/10 at 11:53 AM |
try metals4u - hosts of sizes
jossey
http://www.metals4u.co.uk/products.asp?cat_id=49
how about that.
i get certain measurements from there.
:O)
if it dont help then sorry lol
dave
Minicooper
| posted on 29/6/10 at 12:14 PM |
You certainly can get 40*40*2 as I have some in the garage
| posted on 29/6/10 at 06:51 PM |
40²x3 and 50²x3 are common sizes at most metal suppliers.
Tezza1
| posted on 29/6/10 at 09:31 PM |
If only you guys lived nearer I hold about 20 k of various box sections and tubes for my welding company I scrap pieces under 1mtr somtimes 1.5m
depending on section
MikeR
| posted on 30/6/10 at 09:40 PM |
I'm sure you should set up a division in the midlands. Coventry / Nuneaton is an excellent area.
(plus there are a few on here who'd help you with your car / reduce your steel waste costs).
