New Topic New Reply
Author: Subject: Fury aliminium sill supports
mrwibble
posted on 27/7/10 at 05:23 PM Reply With Quote
How much weight do the forward sill supports take? do you think i'll get away with 3.2mm rivets @ 50mm spacings?
[Edited on 27/7/10 by mrwibble]
clairetoo
posted on 27/7/10 at 05:43 PM Reply With Quote
Mines done with 5mm rivets at 75mm spacing , so I would say it will be fine (assuming the tops of the sill's will be fixed at the front as well ? )
Its cuz I is blond , innit
Claire xx
Will weld for food......
adithorp
posted on 27/7/10 at 08:09 PM Reply With Quote
I think I used the same large head rivets as the floor (4.8mm?).
adrian
http://jpsc.org.uk/forum/
MK9R
posted on 28/7/10 at 07:11 AM Reply With Quote
i have the larger head type just to spread the load out over the rivet
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
mrwibble
posted on 28/7/10 at 10:26 AM Reply With Quote
thing is i forgot to put these on when i put the floor on, so i'm having to drill upwards and its a pita... i think i'll risk it rather than drilling 3.2 pilots then 5mm again.
it is supported above like claire says. thanks for replies.
adithorp
posted on 28/7/10 at 12:09 PM Reply With Quote
It'll be fine. If your worrier thrn use sikaflex as well.
adrian
New Topic New Reply
