New Topic New Reply
Author: Subject: Why have both RU7 and RU8?
v8kid
posted on 10/8/10 at 03:32 PM Reply With Quote
I'm probably being a bit dim and risk embarrassing myself but in the book drawings of an independent rear upright the part the sierra bearing carrier bolts to is a 10mm thick part numbered RU8.
On the upright there is another 10mm thick part numbered RU7 which is welded to the upright.
Why is RU8 needed? Its heavy and does not appear to add to the rigidity.
I see both parts have different internal diameters but on my Lobro driveshafts there are no steps or projections requiring this. Quite the reverse the additional 10m width interferes with the abd sensor location.
Am I missing the obvious here?
[Edited on 10-8-10 by v8kid]
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
deezee
posted on 10/8/10 at 03:40 PM Reply With Quote
RU7 is effectively a spacer so the suspension geometry etc all sits the correct dimensions from the hub. You could space out RU8 using an alternative method, or redesign the hub.
v8kid
posted on 10/8/10 at 03:43 PM Reply With Quote
Ta. It's always the simple (and obvious!) reasons that catch me out.
I take it there are no probs making it out of ally then.
Liam
posted on 10/8/10 at 04:15 PM Reply With Quote
Two slabs of 10mm plate! Mmmm nice. Sounds like lazy design of the upright if you ask me. I'm sure you can do better.
v8kid
posted on 10/8/10 at 04:25 PM Reply With Quote
I still can't really believe it but it seems a viable explanation.
Did a quick stress calc (back of fag packet type) and RU2 seems the weak link so I might not loose any weight overall. Apart from that and the bottom mounting holes being too low the kits of parts available take a lot of cutting and shaping work out - hence the keenness to utilise if possible
Cheers guys
interestedparty
posted on 10/8/10 at 06:45 PM Reply With Quote
Are you building a Haynes Roadster? Have you tried this question on the Haynes forum?
v8kid
posted on 11/8/10 at 08:35 AM Reply With Quote
Ta for the heads up Interested. posted there and see what comes of it.
v8kid
posted on 11/8/10 at 02:17 PM Reply With Quote
Took all of half a day to get answer on Haynes forum!
There is a recess in the drum backplate to suit RU8 and it was left in as a generic design.
Not required for disc brake just make the tube longer
New Topic New Reply
