ettore bugatti
| posted on 26/8/10 at 01:39 PM |
Reynolds tubing Westfield
Interesting reading material!
http://www.nichevehiclenetwork.co.uk/LinkClick.aspx?fileticket=dx9d8Gvp2A4%3D&tabid=266
Bluemoon
| posted on 26/8/10 at 02:06 PM |
Good find. Shows a real application of FE, graphs are interesting shows why testing is needed to demonstrate if the FE model is any good!
Dan
MikeR
| posted on 26/8/10 at 02:08 PM |
very interesting - love to see the details of the changes compared to what cymetrics (and someone else i can never remember) proposed.
robocog
| posted on 26/8/10 at 02:12 PM |
Saw one at Goodwood FOS this year and had an interesting chat with one of the guys working on the stand
Noticed the Reynolds tubing stickers on the chassis, which is what drew my attention
Was blown away how thin the material sounded when "pinged" with fingernail
Interesting stuff indeed
Regards
Rob
| posted on 26/8/10 at 02:40 PM |
Regards
Rob
Totally agree!
Exactly the same as decnt steel cycle frame with double butted tubes. If you fingernail tap it in the middle it almost rings. You can also tell
where the butting occurs and the tube thickens toward the ends.
JF
| posted on 26/8/10 at 03:50 PM |
Sounds interesting. But I'd wait a few years to see how it works in the real world. The company I work for has switched to similar materials
over the years. And although the end product certainly is lighter, it's not a grand succes. Over the years we have experienced more
stress/fatigue cracks with high strength steel, then with the older mild steel products.
So I'd like to see what happens when such a chassis is raced for a few years. Instead of static testing.
Non the less... interesting stuff.
Alan B
| posted on 26/8/10 at 04:10 PM |
What often puzzles me with these exercises, and maybe someone can enlighten me, is that surely in this kind of structural design you are designing for
stiffness? Sure ultimate failure is important and needs consideration, but surely deflections over the the normal range of loading secenarios are very
important too? In that case then, don't most steels have a very similar E value which in conjunction geometrical determined I values drive the
stiffness?
Hope someone can clarify perhaps?
matt_claydon
| posted on 26/8/10 at 08:31 PM |
stiffness?
The thing about Reynolds tubing isn't particularly the type of steel, but the clever process of making the tube relatively very thin-walled
compared to what would normally be used for most of its length, but with thicker walls near the ends to allow strong welded joints.
alistairolsen
| posted on 27/8/10 at 10:01 AM |
you design for stiffness because in general (and it has to be checked) ultimate strength is satisfied FAR before the required stiffness.
My Build Thread
