Author: Subject: Holy cowboy batman, my life passed before me.
bigpig
posted on 3/9/10 at 10:32 AM Reply With Quote
Had one of those moments where you life flashes in front of you today.
After having SWMBO's car mot'ed and a front damper done and the car re-MOTed by them, it sounded a bit clunky. We were told not to worry as its the damper bedding in. Additionally the tracking was out but they don't do tracking and recommended a local specialist.
I went to Walkers in Leicester for the tracking at which point on the ramp they spotted the tracking problem and clunking.....
The drivers track rod end was held on by a couple of mm of thread (i.e. lots of free play).
The track rod end thread is now seized and the guy doing the tracking said I should also query the condition of the hub in case it has been damaged too.
Feck me, I had the serious shakes after seeing that.
I really didn't want to go back to the garage, but given that they should have a chance to remedy the problem I did. What I'm concerned is about the likleyhood of hub damage (its done about 30 miles of normal road driving and a few speed humps). The last thing I want is for them to just slap on a new track rod to find it fails months later as the hub is shot but it was bodged.
I called trading standards who gave me some advice, then called VOSA who said that the MOT was fine as they only do a visual inspection and gave me an advisory of "slight play in track rod ends"
mcerd1
posted on 3/9/10 at 10:46 AM Reply With Quote
what a load of b****t (as you found out)
hope you get it sorted quick (without paying)
I'll count myself very lucky there are at least 4 realy good local garages round here (one I'd completly trust with any car) but even then I still do most of the work myself
StrikerChris
posted on 3/9/10 at 11:01 AM Reply With Quote
I'm surprised at vosa's reply,I'm sure if they pulled you for a spot check and found it they'd of thrown the book at you,they're normally pretty good at that!did the garage have to remove it to fit the shock?if so is be having a hissy fit until they give you a new hub regardless.if not I'd just be glad it didn't let go and give it a little ream to be honest!
ceebmoj
posted on 3/9/10 at 11:05 AM Reply With Quote
a couple of years a go this happened to me on an mx5. The track rod end came of the rack on the motorway I was very lucky to get the car on to the hard solder without hitting any one or them hitting me. clean under ware was required.
bigpig
posted on 3/9/10 at 11:43 AM Reply With Quote
Thanks guys.
I would be amazed if they didn't have to remove the TRE to get to the damper as it was on that side that they took the damper out.
Certainly I would have been amazed if they missed that on an MOT as I would swear they have to check for free play. You could push it with a finger up and down with the thread easily visible between the hub and the ball joint.
I was a bit shocked a VOSA's reply too. I would have thought they take great interest in MOT inspections that miss serious faults.
Either a) this problem had been there a long time and I never knew, which I swear would result in an MOT failure or b) they messed up during the repair.
Given that the tracking was spot on before the repair and on the wee, and having to steer to the right after the work, I think I can tell which way round things went.
[Edited on 3/9/10 by bigpig]
speedyxjs
posted on 3/9/10 at 11:54 AM Reply With Quote
If the MOT was done prior to the new damper and they did have to remove the tre, it may not have been that loose in the MOT. That said, i replaced the front shock isolators on my car yesterday without removing the tre.
mcerd1
posted on 3/9/10 at 12:27 PM Reply With Quote
shounds like they've had it all apart and made a total mess putting it back
I've had the whole front end off my focus twice now for new steering racks(subframe off and everything)
an liitle bit of careful marking and measuring and the worst the tracking has ever been was at the top end of the tolerance (which I then adjusted back to as near the middle as I could)
Danozeman
posted on 3/9/10 at 12:59 PM Reply With Quote
Pardon my langauge but thats the biggest load of bullshit ive ever heard.
As for the hub damage. 30 miles wouldnt have done much damage i wouldnt have thought.
As for vosa. If that wasnt part of the original mot failure and it still got a ticket then they wouldnt be interested. Especially if theyd advised play in the tre's anyway. I think vosa are only interested in pulling dodgey trucks at the moment as that gets them money.
Dan
blakep82
posted on 3/9/10 at 01:26 PM Reply With Quote
just had a camper van drive right at the side of my car. certainly s**t me up a bit! forgeiner who doesn't know how to read road signs or drive roundabouts...
________________________
bigpig
posted on 3/9/10 at 05:10 PM Reply With Quote
Went in. The hub was fine and they were very apologetic. They said they could just tighten up the ball joint as it was still fine & wasn't seized after all, but they put a new one in just to be safe.
The guy said he definitely did tighten up the nut, but looking at the nut the nyloc had failed and the nut shook loose. I guess if there was grease/dirt on the shaft that would have caused that to happen with a nyloc that had been removed and done back up (I thought normally they were only good for one use anyhow).
I think in the end the worrying bit is that I drove with what I though was a loose but seized nut but it actually was loose & could have fallen out.
I think after this, I'm glad at least with an Indy its easy to inspect stuff like that
posted on 3/9/10 at 07:44 PM Reply With Quote
What a load of rubbish. A nyloc stays tight by being torqued correctly in the first place, not due to the nylon bit (which is to prevent a loose fastener completely undoing itself).
He didn't do the nut up, he knows it and is trying to bluff his way out of it rather than admit it.
AndyGT
posted on 3/9/10 at 09:30 PM Reply With Quote
^^^agreed
nothing is impossible
everything is possible
bigpig
posted on 4/9/10 at 11:29 AM Reply With Quote
Yep I agree too. Took it in for wheel tracking at Walkers again who said that for it looks like they have done a decent job this time.
if the bolt is correctly tightend up it shouldn't come loose within a drive home.
