Author: Subject: brakes
tofferson4
posted on 18/9/10 at 08:37 PM Reply With Quote
brakes
hy i have 2 single brake master cylinders with one outlet each like the pic.
Is it legal to use both of them side by side one feeding the front brakes and the other feeding rears or do front and rears have to come from same master cylinders chears
gavin174
posted on 18/9/10 at 08:55 PM Reply With Quote
if you have 2 master cylinders I am assuming you have a biased pedal box.
if so one feeds the front one the rears..
MikeR
posted on 18/9/10 at 08:59 PM Reply With Quote
thats how most are done with a bias pedal box.
It won't pass IVA if you only have one cylinder pushing on all 4 corners.
gavin174
posted on 18/9/10 at 09:03 PM Reply With Quote
MikeR I think your post needs some clarification..
my locost passed IVA with just one standard sierra master cylinder operating all 4 brakes
Dan.
posted on 18/9/10 at 09:13 PM Reply With Quote
perfectly legal but your bias bar must be welded solid.
snapper
posted on 18/9/10 at 09:23 PM Reply With Quote
New requirements for IVA are moving to or have moved to only needing to pin the bias bar, sense is perhaps prevailing
I eat to survive
I drink to forget
gavin174
posted on 18/9/10 at 09:30 PM Reply With Quote
I have heard of one iva tester who is happy with nylocs
aslong as you need tools to adjust that is locked...
[Edited on 18/9/10 by gavin174]
Dusty
posted on 18/9/10 at 09:34 PM Reply With Quote
You can use a single master cylinder like the sierra one but it is effectively twin piston in line in a single barrel supplying dual circuits rather than having twin parallel/tandem pistons in side by side master cylinders supplying dual circuits.
OK, my brain has finally given up the ghost and can no longer tell stork from butter.
Twin/parallel - Two pistons side by side.
Tandem - Two pistons, one in front of the other.
As long as they operate dual circuit brakes they are both legit.
[Edited on 19/9/10 by Dusty]
blakep82
posted on 18/9/10 at 09:57 PM Reply With Quote
in short, yes you can
(and i think you should)
________________________
tofferson4
posted on 18/9/10 at 10:02 PM Reply With Quote
thanks for the quick replys, i dont have a pedal box yet ive still to build one, just needed to check first.
I think ill build a biased pedal box as ive already got the master cylinders just need to decide on fixing bias bar with nylocs or weld
adithorp
posted on 19/9/10 at 08:41 AM Reply With Quote
There's a pretty good description of how to set up a bias bar on the RallyDesign website that has pretty good pictures of how they work.
What you have then is twin master cylinders. The Sierra master is a TANDEM system. Effectivly two pistons, one in front of the other, like the riders on a tandem bicycle. Both systems mean that should one circuit fail you still have some brakes.
adrian
http://jpsc.org.uk/forum/
JF
posted on 19/9/10 at 01:00 PM Reply With Quote
I might very well be wrong... but don't you need a low level warning light these days? Might be hard to do with the integral reservoirs on these?
Just my thoughts...
adithorp
posted on 19/9/10 at 01:08 PM Reply With Quote
I think it can be done with special caps with integral floats.
posted on 19/9/10 at 06:16 PM Reply With Quote
To clarify in case somebody misunderstands
They were requiring the adjuster welded up not the bar. In any event they have back tracked on this.
