contaminated
| posted on 28/9/10 at 12:48 PM |
coil over bush removal
Afternoon chaps
As title really - any suggestions for removing rubber bushes and crush tubes from a shock? In there really tight!
many thanks
Dan
tony-devon
| posted on 28/9/10 at 12:59 PM |
I have only ever worked on bike ones, but they were all bonded in, so maybe some heat required?
perhaps not direct application, but stood in boiling water maybe??
heavy is good, heavy is reliable, and if it breaks, hit them with it
contaminated
| posted on 28/9/10 at 01:57 PM |
That's worth a try - ta
Tiger Super Six Independent
www.southernkitcars.com
matt_gsxr
| posted on 28/9/10 at 02:03 PM |
Drill lots of holes through the rubber. Once the steel tube is out you can get a wet soapy knife in there and scrape away anything that is left.
tony-devon
| posted on 28/9/10 at 04:10 PM |
^ thats a spanking good idea, will remember that for future use
[Edited on 28/9/10 by tony-devon]
contaminated
| posted on 28/9/10 at 04:36 PM |
And it works - job done! As you were chaps.
