Author: Subject: Zetec Clutch
v8james
posted on 28/9/10 at 09:01 PM Reply With Quote
Zetec Clutch
I am going to upgrade the clutch, what is the diameter of the standard 1800 clutch plate?
As I can get an AP racing clutch for a Pinto, which is 215mm and I could get the flywheel redrilled.
madteg
posted on 28/9/10 at 09:13 PM Reply With Quote
That is how i did mine i put a five paddle clutch in had no more problems.
v8james
posted on 28/9/10 at 09:29 PM Reply With Quote
Looks like the job for the winter, destroyed the std clutch last week.
I am using a type9 gearbox, do you know if it has the same splines as the MT75?
Is there any way of fitting a Pinto flywheel to the Zetec crank? As I can get a used lightened flywheel and racing clutch quite cheep.
